Old 02-21-2010, 10:27 AM
clarkkent90xj's Avatar
clarkkent90xj clarkkent90xj is offline
another 8 lug front question
I have an option to pick up a late 70's 3/4 ton chev truck. 4.10 gears, 14 bolt rear, 10 bolt front axle. my question is, will the outers fromt the 10 bolt work on my 44 front to make it a 8-lug? how 'bout high steer? I'm still spring under, but that could change any given weekend...
thanks, kent
'90 xj , crushed
'85 GW, comming up.
Old 02-21-2010, 10:42 PM
Blake Blake is offline
Yes, the outers on D44 and 10 bolts are the same. They share the same ball joints.
Slap the 8 lug outers on and call it good.
Old 02-23-2010, 09:38 AM
rawdave's Avatar
rawdave rawdave is offline
I agree. See signature for a link to a write-up on the parts and how to do it.
(This article was actually written using chevy 3/4 ton D44 but I would guess it is the same)
"You fancy people with your shoes."
87 Grand Wagoneer
2009 GMC 5.3L Vortec
Sterling 10.25 Rear
8 Lug J10 Front
TSM Mfg Rear Disk Brake Conversion
33 Gallon Rear Poly Tank
69 J-3000 Pickup
Plans:
2.8 Cummins Diesel Repower
6L90
Atlas Transfer Case
