Just wanted to let you guys know that if you need some good high strength bolts you might want to check out your Caterpillar dealer. I work at the one here in OKC and use Cat bolts for everything. We got a bunch of sizes in fine and coarse thread. No metric fine thread though. We even have allen head bolts. The prices aren't too bad either. All the bolts we have are at least grade 8. We also have thick washers. Just thought I would let you know cause I know its hard to find good bolts for cheap. If anyone needs any I can get them for a discount and ship from here for cheap. Not looking to make money, just helpin out. Anyway just an FYI
Good Bolts.....
No charge, he'll just thow them as you drive by...Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
?Freedom is never more than one generation away from extinction? by Ronald Reagan.
Good Post!
Mechanic friend of mine swears by their fasteners. He said he would use them anytime he needed to know for sure a bolt would live up to it's quoted specs, especially in these days of counterfeit grade 8 bolts showing up at many hardware stores (there were some threads about this awhile back).
Todd1971 Wagoneer Buildup:
Part I: http://www.ifsja.org/forums/vb/showthread.php?t=66564
Part II: http://www.ifsja.org/forums/vb/showthread.php?t=69476
Part III: http://www.ifsja.org/forums/vb/showthread.php?t=80046
Part IV: http://www.ifsja.org/forums/vb/showthread.php?t=87303
Part V: http://www.ifsja.org/forums/vb/showthread.php?t=129156
