Pretty easy upgrade, grabbed a set of front belts from the junkyard. Taking the family to Moab in a few weeks and wanted to bet better belts. I have never liked lap belts.
"After years of being paranoid about my Jeep?s temp going towards that 220F mark, I?m realizing that if it was real problem, Jeep engineers would have painted that area RED." - FSJ Guy
Spend the day yesterday at a friends getting the front bumper and rock sliders installed. Everything went fairly well and I am pleased with it. The front bumper sticks out a little farther than I wanted but since the bumper was originally designed for an older rig I couldn't get it up as tight to the valance as I wanted with out some major modifications to the bumper or the Jeep. Next I need to save up for a winch! Enjoy the pics.
looks sick!! where did you get those rock sliders??
1988 GW AMC 360/5.9/V8 - 4'' block lift, 33'' tires, aussie locker in the rear, HEI distributor, BJ crossflow radiator, Flow Kooler In Garage - ebrock perf intake, 1406 ebrock, On Order cliffhanger bumper(swingout), 1' body lift with new bushings http://s467.photobucket.com/albums/r...nd%20Wagoneer/
what was the torque setting that you used on the rear bumper?? My bumper is leaving BJ's tomorrow
Rather than fixing the axle which isn't good for large tires anyway, I have officially started my SOA/SF and axle swap. The axles came from a 79 F*rd F-250 so its a HP D44 8-lug front and a D60 rear with 4.10 gears. I am also swaping the stock fuel tank with a 33 gal tank. I am trying to get all this done before Ouray. Here is a list of things I have and thing I need.
Have:
Axles
Rear Disc Conversion kit (with e-brake)
High Steer Arms, tie-rod and drag link
Shackle flip kit
1310/1350 U-joints
Front Rotors turned and ready to go
Need:
Stock springs (ordered from BJ's)
Shock mounts (ordered from BJ's)
Front brake pads and caliper rebuild kit
rear brake lines
Rims
Tires
33 gallon fuel tank (ordered)
I have all the axle parts painted and ready to go. I will be starting on the shackle flip in the next couple of days. I don't want to install the front axle until I get the springs so I am at a stand still. I also dont want to install the axles until I get the shock mounts welded since it will be easier with the axle out.
Here are some teaser pics of the rear axle painted and mostly assembled.
