Old 03-23-2017, 08:45 AM
RAMBLINFSJ's Avatar
RAMBLINFSJ RAMBLINFSJ is offline
Trans Swap Question
The transmission in my '90 Wagon has lost second gear. I bought an '84 Wagon with a good transmission. And of course after I bought the parts Wagon, I realized it uses the Ford style starter and the '90 uses the Motorola starter. Is the starter bolt pattern the same on the transmissions?
1984 Wagoneer
1977 Cherokee Chief (401)
1982 J-20
1965 AMC Rambler American 220
Old 03-23-2017, 11:12 AM
Transmissions are the same '80-'91.
Flexplate, starter, and wiring is the difference.
Old 03-23-2017, 12:37 PM
RAMBLINFSJ's Avatar
I thought so but had to make sure. Thanks man!
1984 Wagoneer
1982 J-20
Old 03-24-2017, 06:48 PM
Marineviper's Avatar
Marineviper Marineviper is offline
Would your original go through first fine, then slip through second then finally go into third?
76 j10 short, 360 nailhead th400 D20, 3.54, 4" lift, 31" bfg ko2
HEI
CS130 105amp
Comp cam sk10-200-4
Edelbrock performer w/1406
Old 03-24-2017, 06:52 PM
Just wondering cause if the front band never gets adjusted it will become loose and a little pawl (looks like a metal wedge) can fall out. It's worth the cost of fluid and filter kit. But then again you could swap trannys and fix that one and have a spare.
HEI
CS130 105amp
Comp cam sk10-200-4
Another 4.0 head swap question blackj10 General FSJ Tech 8 06-06-2013 09:45 PM
Axle swap question fsj1979 General FSJ Tech 3 11-05-2012 07:35 AM
yet another np229 swap question leopold General FSJ Tech 9 06-25-2012 08:30 PM
Transfer case swap question... Metal Twister General FSJ Tech 16 11-11-2009 08:50 PM
trans question abj10 General FSJ Tech 7 04-11-2007 07:50 AM
