Old 11-24-2015, 01:18 PM
RAMBLINFSJ's Avatar
RAMBLINFSJ RAMBLINFSJ is offline
Does this trans need rebuilding?
A friend of mine bought a '90 Wagon. The transmission skips right past 2nd gear into 3rd. I adjusted the kickdown rod which made no difference. Then I learned about the front band adjustment. I backed off the lock nut and was able to run the set screw all the way in by hand. It never had any resistance on the set screw to even reach the 72 in/lbs required. Does that mean something in the band assembly has gone wrong? Will the transmission need to be rebuilt?
1984 Wagoneer
1977 Cherokee Chief (401)
1982 J-20
1965 AMC Rambler American 220
Old 11-24-2015, 07:28 PM
redwoody redwoody is offline
you'll need to drop the pan and valve body and see if the band broke or possibly the metal piece fell from adjustment screw.
88 GW hei E-fuel pump 360
Old 11-25-2015, 10:51 AM
RAMBLINFSJ's Avatar
That's what I was afraid of. Digging into an automatic transmission is above my pay grade. Thanks.
1984 Wagoneer
1982 J-20
Old 11-25-2015, 11:29 AM
serehill serehill is offline
Gone,Never Forgotten.
although messy
Pulling the valve body is relatively easy.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Engine and trans ID ...and other things I need lockedcj7 General FSJ Tech 2 01-06-2009 08:16 AM
727 trans shift points? Dogs-in-the-back General FSJ Tech 2 05-02-2005 06:58 AM
Eng... Trans... Transfercase.... SWAPING Gramcracker General FSJ Tech 2 01-19-2004 10:33 AM
my trans is shot, should I rebuild or buy a used one? Dude23455 General FSJ Tech 24 11-02-2002 12:37 PM
Is this a factory trans cooler? Thomas DeBusk General FSJ Tech 8 07-11-2002 02:45 AM
