Doors are in color. Right one turned out well. Left has a run on the window frame and another just below the door handle. The media blaster told me "satin black is not your friend if you get a run....difficult to blend in a repair...might have to repaint the whole panel...." The window frame is easy....I'll just sand it out, mask the rest of the door and shoot it again. I'm thinking I might get away with a spot repair by the door handle....or maybe mask across at one of the accent creases, and spray above.... Any advice from y'all is much appreciated.
The polyester primer worked out well, panels are straight as an arrow, although there are some sanding scratch marks in the paint. That primer is very soft and sands easy, but it loads up fine grit sand paper very quickly. Guess I got tired of endless sanding. Next time (fat chance) I'll block it with 120, sand with 220, and then spray on a coat of urethane sanding primer. I find it much easier to work with fine grit paper as it is not quite so soft.
The "easels" worked well. Had to lay on my back to shoot the bottom edge of frames....otherwise great access. One step job instead of spraying the back side in a separate session from the exterior. (There are two 1x2's sticking out from the easel. They slide into the access holes on the back side of the door).
DSCN1534 by Rufus, on Flickr
DSCN1535 by Rufus, on Flickr
DSCN1536 by Rufus, on Flickr
DSCN1538 by Rufus, on Flickr
DSCN1537 by Rufus, on Flickr
DSCN1539 by Rufus, on Flickr
