Old 07-07-2013, 04:15 PM
Clay Balke Clay Balke is offline
steering wheel removal?
Any tips on pulling the wheel off the splines without tearing the whole column up/off? Special tool required? Going to replace the turn signal switch/harness and see if this solves my electrical gremlin.....
Old 07-07-2013, 04:21 PM
Tripwire's Avatar
Tripwire Tripwire is offline
you need a wheel/balancer puller DO NOT use a hammer or you will be replacing the column
if you are going deeper into it then you need a compressor tool for the lock plate
both tools should be about ~15 bucks apiece - dont try and remove the plate without it as you can end up silly looking and seriously hurt
you may be able to rent them for ten a piece - but whats the point?
Abort? Retry? Ignore? >
Old 07-07-2013, 04:32 PM
serehill serehill is offline
Gone,Never Forgotten.
all you need to know
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
http://ts1.mm.bing.net/th?id=H.48697...=169&h=126&p=0
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 07-07-2013, 08:21 PM
FSJ Guy FSJ Guy is offline
X2 on the lockplate depressor.
Ethan Brady
www.bigscaryjeep.com
Old 07-08-2013, 04:17 AM
budryzer's Avatar
budryzer budryzer is offline
Harbor freight carries the pullers cheap. I self made the c clip tool/
85 GW 360/2v
SOA/SF 36's
68 AMX
04 BMW 325
85 FLT
77 Hercules 250
ASUS laptop with theamcfurom.com as homepage
Old 07-08-2013, 09:47 AM
pcoplin's Avatar
pcoplin pcoplin is offline
I used the puller in reverse to depress the lock plate.
Don't forget the pivot pin remover if you're going that deep, too.
85 Wagoneer 5.2/44RE/NP229
98 TJ 5.9/46RE/D300
01 F250 Powerstroke
***Space saved for a J-truck***
Lifted GW - Crooked Steering Wheel? Extremesolo General FSJ Tech 5 01-23-2012 10:25 PM
Steering Wheel off center silvercert General FSJ Discussion 3 01-03-2012 03:06 PM
Steering woes continue, getting annoyed... DanHS General FSJ Tech 11 06-22-2011 08:46 PM
Dead Spot in Steering Wheel heep2jeep General FSJ Tech 3 07-21-2008 01:59 PM
steering wheel worn and torn? -READ THIS- youngjeeper General FSJ Tech 7 06-09-2004 12:08 PM
