Old 06-30-2013, 04:07 PM
FSJ Guy FSJ Guy is offline
I found my A/C!!! :-p
I was told that the limousine did not have air conditioning when I purchased it. But when I removed the covers on the front divider and the rear-facing seat, I found the air conditioning unit for the back.
I don't have power to the fan, yet, however. But everything else in the back (heater fan, lights, radio, liquor dispenser) has power.
For some reason, the A/C lines are SPLICED into the OE lines. As in spliced, I mean the lines are slipped over a hose barb and a regular hose clamp is used to hold the hose on. Is that kosher???
Once I get the blower motor working, I'll work on redoing the A/C lines correctly and getting a charge into the system.
Ethan Brady
www.bigscaryjeep.com
Old 06-30-2013, 05:59 PM
jsinajeep's Avatar
Yes to the spliced joint. That what they used when they put an after market A/C unit in the new van I bought in 77.
Old 06-30-2013, 06:50 PM
Interesting. I never thought of splicing a line that has, what, 200 PSI or so?
Ethan Brady
Old 06-30-2013, 07:42 PM
jsinajeep's Avatar
I have used the "T" fitting when I add a rear unit in the van also. Most unit will not have 200#
at any time that I have worked on.
Old 07-02-2013, 01:36 PM
Zigged 79 Zigged 79 is offline
Well you just reminded me of another project I should do. Of course if I wait long enough it will be winter 2013 , then i can think about it again in summer 2014.
A/C system, pressure switches? pcoplin General FSJ Tech 5 05-20-2013 08:48 AM
Troubleshooting Power to A/C controls Smiff General FSJ Tech 2 07-26-2010 09:30 PM
Another A/c repair Smiff General FSJ Tech 3 07-24-2010 10:56 PM
A/C blower is back GED General FSJ Tech 0 07-05-2004 04:16 PM
belts from alternator to A/C leila General FSJ Tech 9 08-16-2001 01:46 PM
