Old 05-19-2010, 04:14 PM
juggernautsb juggernautsb is offline
401 with 2 barrel carb?
Another question from a new guy. I talked to someone about buying a Cherokee with a 401, and he said it had a 2 barrel carb. Is there such a beast? And what can anybody tell me about it?
Old 05-19-2010, 04:34 PM
Not from Jeep, AFAIK. There were some IHC trucks with 2V AMC 401s. It would be easy to fit a 2V manifold from a 304 or 360 and run a 2V, however.
Old 05-19-2010, 04:36 PM
CA again....
Certain years if you wanted a 401 in CA it was factory equipped 2bbl.
Old 05-19-2010, 04:54 PM
J20 project's Avatar
Better look at the block casting before you buy.
J20
BP Drivetrain...........
775-537-7918
Old 05-19-2010, 05:37 PM
J20
Indeed. VIN and stickers may say 401 but the block says 360. That would explain the 2V.
Old 05-19-2010, 05:57 PM
Tornado230's Avatar
Back in the days when they were new, there were problems with the 4-barrel Motorcraft that some dealers could not deal with.
The fix was to put on a 2-barrel manifold and 2100 carburetor.
I have been running a 2100 on the 401 for 10 years. Works for me.
Old 05-19-2010, 11:33 PM
mud89's Avatar
mud89 mud89 is offline
With the 2 barrel it's ok for torque at low rpm, but you should have a lack of power at high rpm
Old 05-20-2010, 07:27 AM
dlowrance's Avatar
dlowrance dlowrance is offline
I've got a 401 with a 2V waiting for me to rebuild it...came out of a J truck. No idea if it's stock or not but why the heck would someone take OFF a 4V and ADD a 2V?? So I assume it's from the factory that way...
Dale
80 W/T Cherokee - "Liz"....4bt??
69 J3000 DRA Dump - King Triton!!
Old 05-20-2010, 10:23 AM
mud89's Avatar
Maybe they expect an improvment for mileage or emissions , but it's indeed a pity to reduce the perfs of a 401..
Rebuilt 401 Cam Break In and Dyno Runs crazydog General FSJ Tech 15 07-22-2010 10:29 PM
AMC/Rambler 327 4 barrel intake and carb The PIG Smith General FSJ Discussion 8 08-14-2007 04:26 PM
Motorcraft 4 barrel carb to edelbrock intake amc75matador General FSJ Tech 4 02-20-2006 08:31 PM
The 401 revisited Elliott General FSJ Tech 20 12-14-2003 12:41 PM
Rebuilt carb ----> Gas leak! (UPDATE) jode General FSJ Tech 15 11-25-2002 05:10 PM
