Old 04-21-2011, 06:12 PM
Keanu151515's Avatar
Keanu151515 Keanu151515 is offline
Nice weekend for a light engine rebuild??
so today i decided to start a light engine rebuild on my 78 J10. finally got all the parts together for it
-Headman Headers
-Full Engine Gasket Set
-Thermostat
-Plugs
-Comp Cam Push rods
-Spare Rocker Set
-Spark Plugs
-Flex-A-Light Fan
-Original 2bbl Intake from my 71 Javelin (pre emissions)
-100 amp Alt
-Ect.
Here is what im starting with, original 360 2bbl with 93K miles
so every thing starts off good and getting things off fairly easliy. althogh stupid clutch fan cut my hands all up trying to get off.
get the intake manifold and rocker covers off and find this. . .
Looks like the Previous owner never changed the oil
okay, whatever so a little more deep cleaning is gonna be needed. . .
i start on the rockers, getting them out and i find out one had a bad crack and ended up snapping when i loosened the bolt
now i move on to the exhaust manifold start getting the bolts out and notice 3 in the back already had rounded heads . now i have ended up rounding 2 more bolt heads and snapped another in the head
so to calm my self down i decided to start cleaning and repainting some engine parts. got original amc metallic blue
anyone know a good way to get the 5 rounded bolts out? im working out of my apt. parking lot so options are a little limited
1978 Jeep J10 360 4bbl, T18A 4spd, D44 axles
1971 AMC Javelin SST 401 4bbl, 727, Drag car
1967 Pontiac Bonneville Convertible 400 4bbl, T400, newest project
My other vehicle is a U.S. Navy Hovercraft (LCAC)
Paved Roads: Another Fine Example of Unnecessary Government Spending
Old 04-21-2011, 06:38 PM
the last 3 or 4 manifolds I had to take off all had bolts that were rounded.. I used a 12mm deep socket and lightly taped them on to the bolt. worked great. the taping of the socket onto the bolt also makes the bolt eazer to get out..Breakes up the rust.
you have to pound the bolt out of the scoket after you take it out of the head.
just make sure when you turn the bolt they do not break off in the head.
Old 04-21-2011, 06:59 PM
bigwoody's Avatar
bigwoody bigwoody is offline
I have had success with craftsman bolt outs. The only problem I've had is twisting the head off.
http://www.sears.com/shc/s/p_10153_12605_00952166000P
HI MY NAME IS AL AND I'M A JEEPOHOLIC
83,87,88 GW..79 J10
Old 04-21-2011, 09:48 PM
temps425's Avatar
temps425 temps425 is offline
LOL! Funny post.
Old 04-22-2011, 01:32 PM
NEED HELP
Okay, so I got the bolt out kit. Snapped another bolt in the manifold. Not to worried about it. Now I have seriously rounded the other 4 bolts. Even the bolt outs just spin. Anyone got other ideas? I need serious help. The truck has to be running by Monday. Would be done tomorrow if it wernt for the exahust manifolds giveing such a problem
Help!
Old 04-22-2011, 01:35 PM
grind the heads off,slide the manifold off and pull the studs out with a vice grip.
Old 04-23-2011, 08:31 PM
day 3
well, got the exhaust manifold bolts cut with a sawzaw .
got a friend who goes to ATI for automotive removing the leftover studs for me.
after i got the heads off i went through a lot of sea foam, carb cleaner, and brake cleaner to get it all cleaned up. man was it full of sludge!
and to end the wonderful day i started to get the block repainted!
Old 04-23-2011, 08:35 PM
TIMING CHAIN TIMING CHAIN TIMING CHAIN!!!!!
and get that oil pump set up while the cover is off!!!
Old 04-26-2011, 07:10 AM
engine heads
so talking with my friend at ATI. 3 of the head bolts came out with a little persuasion. the other 3 had to get completely drilled out and hela coils placed in. hopefully the heads come back tomorrow and i can get the rest of this engine together.
Old 04-26-2011, 08:13 AM
Ditto
Old 04-26-2011, 12:03 PM
backroadin''s Avatar
Man, seems nothing is ever "just a weekend" project!!! Kinda like stopping at the bar for "just a beer"!! I've still got weekend projects going!!!
Hope it all has a good ending.
Looking for Engine rebuild kit for AMC 360 matthew440 General FSJ Tech 4 04-06-2009 01:10 PM
considering an engine rebuild johnwaynejeep2 General FSJ Tech 2 01-23-2006 07:11 AM
Need Expert Advice On Engine Rebuild!! Rompn General FSJ Tech 7 12-31-2003 09:45 AM
Engine rebuild, or engine swap??? MacGordon General FSJ Tech 6 03-11-2003 11:13 AM
Engine rebuild / replace advice... ?? -long SFFSJ General FSJ Tech 2 03-06-2003 07:16 PM
