Old 01-17-2009, 09:59 PM
amc75matador's Avatar
amc75matador amc75matador is offline
header paint
How do I remove the black anti rust coating to paint my hedman headers with high heat paint?
Sleep, Eat, Jeep, Repeat...
"I need Another Jeep!"
"The streets will flood with the blood of the non-believers!"
"Of all the things I've lost, I miss my mind the most!"
"Nothing makes a person more productive than the last minute"
Old 01-17-2009, 10:24 PM
djongeward's Avatar
djongeward djongeward is offline
I think I would just prime with high heat, sand a bit and go with the high temp enamel. Make sure it is the really high heat stuff. I think there is two grades out there. I have also used black stove paint. It is extreme high heat and won't come off for nothin.
89 Grandwagoneer, built 360, COMP cam set, port matched Edelbrock SP2P, 475 cfm Holley ORA, Thorleys, MSD6a, extra cooling and oiling.
76 Cherokee S Chief - rebuilt stock, Holley, Performer, MSD Dizzy.
89 GW parts waggy
Old 01-18-2009, 10:11 AM
Chevelleguy's Avatar
Just run 'em. It'll burn right off.
Old 01-18-2009, 10:29 AM
That is what I am talkin' about!
Old 01-18-2009, 10:52 AM
Ron H's Avatar
Ron H Ron H is offline
I have used stove paint and it does hold for awhile but eventually burns off, i suggest if you are looking for looks ceramic coating is the best way to go, i ceramic coated my headers on my mustang 5 years ago, and it still looks good.
Old 01-18-2009, 11:05 AM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
You shouldn't paint them do all you can to let heat escape those thin metal headers will warp faster when coated or wrapped. That's y most header wraps void warranties cuz its thin metal
