Old 01-03-2009, 02:23 PM
ferretjuggler's Avatar
ferretjuggler ferretjuggler is offline
Cheap suspension lift?
Get ready to cringe guys. Dumbass proposal coming up.
Imagine I was doing a ground up build on a FSJ wagoneer for example, and I wanted, say, a 3" lift all round.
What if I extended all the spring mounts on the chassis down by 3".
Like Fr & Rr fixed mounts, the Fr & Rr moving shackle mounts, and the shock absorber mounts too.
I know there's other issues like propshaft angles and steering linkage.
But I can't see any real reason it wouldn't work.
Maybe the spring mounts might tend to ground out compared to a normal lift kit, but I bet it would be a lot better than stock.
Old 01-03-2009, 02:39 PM
imiceman44 imiceman44 is offline
Much easier to do is a Spring over axle in the front and shakle flip in the rear with a 1" or 2" block.
The whole thing cost me less than $100 and I did it in one afternoon.
Messing with spring mounts for a moderate lift is not necessary on the FSJ.
If you want more then you will need a different approach.
By the way I didn't count the shock or the driveshaft cost since you have to deal with that with any lift, I didn;t need to do anything to the shafts but put new shocks all around.
IceMan
Old 01-03-2009, 02:58 PM
jeepjerry's Avatar
I have always had that idea also but have never tried it. I would just make plates to weld on and lower the spring mount hole down and then box it all in. Should be plenty strong plus you have stock spring ride quality. If you dont try it i might, but let us know if you do.
1977 J-20, 4bbl AMC 360/t-18,33"s.
1976 CJ-5, Healthy AMC 360/t-18, 6" lift, 35"s.
1972 Javelin SST, mild AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 01-03-2009, 03:07 PM
I'm gonna try it on a CJ7 first, I'm pretty confident at fab/welding and stuff.
I've got more CJ stuff than FSJ, if it don't work I can live with it.
Old 01-03-2009, 03:22 PM
Actually I have wheeled several times with one of our AZ members who did a very similar setup.
Sort of like this:
He removed the back rear FSJ hangers and flipped them over and used a shim to correct the pinion angle. Sort of a down, dirty and quick shackle flip.
He then lowered the front mounts by about 3-4" (or what ever it took to equal it out) on some box tube and braced it all in.
It's not an SOA/Shackle Flip at 6-7" but it wheels quite well.
I'm not sure what the suspension on a CJ7 looks like, probably real simillar to ours up front, but I'm sure it's very doable.
Old 01-03-2009, 04:03 PM
I don't want to confuse the issue, but....
I had a plan to build a 4 door crewcab J series pickup with a full 7' bed.
Due to circumstances changing I've got to put that on hold for a few years.
So I'm gonna use what parts I've collected for the project on one of my two SJ 4 door Cherokees (the rough one I was gonna hack for the pickup)
I got Chevy Blazer half ton GM axles, an inch or so wider than J10s.
Front axle is SOA with the spring pad cast into the pumpkin.
Rear is SOA but with narrower spring pad spacing than SJ, so I'm going to rework the SJ rear chassis to a springs under the chassis rails design to equal whatever lift I've got at the front.
I've had the measuring tape all over them and I'm confident it will work.
OK so this aint quite what I described above but the rear end more or less is.
I posted the thread just to see if the idea was a no-no, like:
"my buddy tried that and his chassis snapped in half"
Old 01-03-2009, 04:42 PM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
You said it not me. Bad idea. Unless you are building sgt.rock from Trucks and are gonna run 54" boggers with 6" lift springs sprung over? you would be way ahead with a liftkit. Only reason to do that is just tosay you did it. Hellcreek makes a 3" lift and bj's makes a 4" lift. Go that route its new springs, a better ride and way less work
What? As far as ride height cuz you still have wore out springs and lots of other problems associated with it. The back shackle hanger will be a real pain unless you inboard the springs to drop it. Just say no to dumbass ideas
Old 01-09-2009, 09:52 PM
jsinajeep's Avatar
I disagree, I done the 2"x4" tube welded to my frame and used the stock springs. Everybody that ride with me tell me how nice it ride compaired to the ones they driven with the 4" spring lift. That be my 2 cent worth. And it wheels real nice.
Old 01-09-2009, 09:57 PM
jeepjerry's Avatar
Got any pics of it?
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 01-09-2009, 11:38 PM
incommando
Posts: n/a
www.ttfabworks.com
You will not be disappointed.
Old 01-10-2009, 12:18 AM
1977cherokeechief's Avatar
1977cherokeechief 1977cherokeechief is offline
you beat me to it... but i was thinking that it is a good idea, cheap, easy, and quick, and can be really strong if built right.
i was thinking about something like that because i do not want to fork a lot of money for something that could get wrecked at any moment while on the road...
nate
the new fixer upper
1977 cherokee chief
360, th400, QT
33" tires
edelbrock 600cfm
82 mustang 5.0 5 speed. ford racing intake, edelbrock, offbrand long tubes, and glass packs.
Originally Posted by jamsni
Just explain that you are trying to do your part to stimulate the economy. Buying it is just the right thing to do.
