Old 02-09-2020, 02:18 PM
Tripwire's Avatar
Tripwire Tripwire is offline
what to use to glue bumper step trim in place ?
I had to repair my Caddy SRX rear bumper cover, since it was a complete re-spray, I removed rubber/plastic step strip on the top that was held in with brittle clips/tabs
Needless to say I broke most of them off..... instead of forking out a hundred bucks for a new one I was contemplating gluing the thing in place but i am not sure what to use, i was thinking black RTV or something as there is ribbing that allows water to seep out so contact cement would not work
any thoughts?
steve
Abort? Retry? Ignore? >
Old 02-11-2020, 12:58 AM
any thoughts?
steve
3m double sided tape works well. Or rubber butyl cement if you need some water proofing and moldable.
Old 02-11-2020, 08:27 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
I agree with shag wag,....3M tape may work
or 3M Fusor, but that is high dollar
and requires a special gun to dispense I think
if none of those work
maybe a jb weld type product that works on metal/plastic
and I have seen some small twin tube epoxy glue in wal mart, parts stores etc.
some of those are formulated to bond plastic/metal etc....
hope it works out.
dave in NC
How to install aftermarket trim - Pic heavy ! Tripwire General FSJ Discussion 17 11-07-2012 06:00 PM
A Very FSJ Breakfast. (A 7 step program) Heavy_Metal_Thunder_81 General FSJ Discussion 25 03-01-2012 04:28 PM
cheapest place to buy front bumper rubber 3rdelement General FSJ Discussion 13 11-21-2010 07:31 PM
J Truck side trim differences red mistress General FSJ Discussion 14 03-27-2009 07:00 AM
Best winch bumper Don in Missouri Off-Road FSJ Tech 2 10-16-2004 12:31 AM
