Old 09-01-2018, 07:01 PM
JPSwapMohn's Avatar
JPSwapMohn JPSwapMohn is offline
Where do you get your Glass?
I dare venture into the FSJ-PRIS universe uninvited..
You all may have seen my WT wagoneer build currently happening. Looking at my window glass, I have realized it is going to look really crappy with new shiny paint..
Primarily, I need the actual door window glass for all 4 doors on a 86-91 GW with electric windows. If I understand correctly, the manual glass is a little different, and I am not sure if the glass changed when the electric window mechanisms changed.
So, where do you PRIS folks source your windows? Am I left roaming the junk yards hoping to spot an un-scratched window on a rusted out rig?
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP242, F150 fuel cell, discs, Aussie rear, LDS front, 4.10s
http://imgbox.com/g/rNuIasKYrS
95YJ, STaK 300, D44's, SOA, ARB's, 4.56s, Bilsteins, 35" KM2's
50 CJ3A
77 J-10, 360/T-18/D20, SOLD
Old 09-01-2018, 07:21 PM
Tripwire's Avatar
Tripwire Tripwire is offline
the glass is the same for flextrack or cable style lifters
i have all 4 but shipping would be expensive, the glass is good shape no "scratches" but normal life wear, any good glass shop can polish them for you - have you thought of that?
steve
Abort? Retry? Ignore? >
Old 09-01-2018, 09:42 PM
If yours are intact a glass shop can use them as patterns and cut you new ones.
Old 09-01-2018, 10:32 PM
Yep. And it doesn't cost as much as one would think. I've had a local glass shop here cut me some glass for around the house a few times. i am usually pleasantly surprised at how cheap it is.
Old 09-02-2018, 12:44 AM
men in black's Avatar
Had a local shop cut a 30% tint 3/16" rear window, 50% is too dark if you have tinted side windows. Had to lower it to backup.
Old 09-03-2018, 07:02 PM
JPSwapMohn's Avatar
We will try a local shop. There are some deep grooves cut into a couple of the windows that i don’t think will polish out.
The 30% tint is good to know! We talked about it, but i wasn’t sure how dark to go. Don’t want the PD to pull me for too dark (happened on a truck i bought a few years back locally that I bought with tint already applied).
50 CJ3A
Old 09-06-2018, 01:59 PM
SJTD SJTD is offline
It'll cost more than typical window glass.
It's thicker, you want the edges ground and they need to have it tempered after cutting/grinding.
MIB, where'd you get tinted glass. I called around and no one could do it.
Sic friatur crustulum
Old 09-06-2018, 09:54 PM
Just a local shop in Fenton, Mich. They cut it and sent it out to be tempered.
IIRC $150.00
Old 09-07-2018, 10:09 AM
Correct me if I'm wrong...but isn't the lower the percentage the less light the tint allows through, therefore making it darker? So 30% tint should be darker than 50% tint. My 2017 Ram has ~30% from the factory and I tinted it darker to ~15%.
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1984 J10 - Parts
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 09-07-2018, 10:26 AM
That's how I understand it, too. I think the % value is percent of light allowed through the tint...
Old 09-19-2018, 10:34 PM
Old Ironsides's Avatar
Old Ironsides Old Ironsides is offline
Can you get a glass shop to do a light mirror tint like some of the factory FSJs had? I always loved that look, especially on the CCs.
Grant
'76 J-10, 401 (1406/2131/DUI/RV Cam), TH400, Part Time, 3" lift, 33s, 346K Miles
'75 J-10, 360 (1406/2131/MSD), TH400 QT, 6" lift, 33s, 100K Miles
'77 Cherokee Chief, 401/Th400, QT, 4" lift... Totalled
Old 02-02-2019, 07:15 AM
Crist Clapper's Avatar
I'm being stalked by Steve... Save me!
Glass restoration
This may not be cost-effective for you, but will just offer it as an option. I wanted to have all the glass on my XJ to have the same original stamping, and the scratches were very deep. I was warned that any polishing would create a "rainbow" reflection, it did not.
Here's who I used: https://glassrestorationinc.com/
1990 Grand Wagoneer:
1987 XJ Wagoneer Limited:
Desiree - def: “Much Desired” [orig: French] Desirable Charcoal Gray façade, Wood-grain vêneers,and Tan Leather éssentials"
Member, FSJ Prissy Restoration Association (FJS-PRIS)
Do I have a tailgate glass problem? tenoverthenose General FSJ Tech 6 08-25-2017 10:28 AM
Tailgate Glass Stuck farrelljt General FSJ Discussion 7 02-03-2017 05:11 PM
Help! Cherokee rear quarter glass ygbsm General FSJ Discussion 4 10-15-2011 07:38 PM
How to tint a FSJ (MODS PLEASE STICKY THIS SOMEWHERE) Chrome General FSJ Discussion 29 06-17-2009 04:58 PM
rear glass channel orientation jeepshots General FSJ Tech 3 03-27-2009 06:26 PM
