Hey guys, hoping an AC guru can help me out..
I'm working on a rebuild and conversion to R134a of my factory AC system. When I got the Jeep two years ago the system was closed but empty. Found a twisted metal line at the condenser that was probably a slow leak. My York isn't in great shape so I found an old rebuilt Sanden SD-508 to install with the adapter mount. I am waiting on fresh barrier hose and fittings to adapt the Sanden and replace the old crusty R-12 lines. I have a new condenser, drier, expansion valve, switch/thermostat and compressor. The evaporator is not being replaced. I am also 86'ing the in-line sight glass while keeping the low pressure cut-off switch.
This being said I'm lost on oil fill capacities. I have the TSM but it offers about a sentence worth of content with oil. The Sanden may or may not have oil in it. If it does there is a chance it is mineral oil. It appears its sat for many many years on the shelf. It's still capped and pressurized from storage and I don't want to open it up just yet.
My plan is to drain any oil in the compressor and add Ester 100 oil instead of the recommended PAG (SP-20 / SP-15) so any residual mineral oil is accounted for. I'm just not sure how much. Sanden has charts showing what the compressor takes but I'm not sure if that accounts for what might be left in the rest of the system.
The entire front end of the Jeep is disassembled, AC unit is pulled completely, so now is the time. I am also wondering how long these new parts can sit connected but with no charge/vacuum pulled and remain ok.
THANKS!
THANKS!
