i'm getting the new power plant put together for the wt. i like the nickel look of it, but will it hold up??? should i paint it or can i put a clear powder coat on it with out harming it ?? heres a pic of it on the motor in it's raw form. you guys and gals that have them how they holding up unpainted. thanks for any help.
bulltear plated timming cover Q/ w/pic
baybilly = dave
77 cherokee S ,parts
84 J10, parts
51 Willys
88 XJ, DD
1966 GT-350 mustang/ projectTags: None
my Dad used to nickel plate stuff..seen his stuff 25 years later (guns)..no tarnish. Granted guns aren't engines but..I wouldn't paint it If it ever started flaking, even clear coat, it'd look like CRAP. If the plating is porous or rough, maybe smooth it out a little with a buffer pad on a dremel so the gunk (if you have any) doesn't build up in it..but the plating should be smooth and fine as is. Shoot once all your accessories are on there, you won't be seeing much of it anyways...
just my 2 cents..1979 Chero S "Sundog" 1979 Chero S "Hammer"
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
You have the holy grail of AMC timing covers/oil pumps!! Do not coat or cover that beauty with anything!!!! It is rare and tough!!!AMC/Jeep Forum
Send me more pics of this [email protected]AMC/Jeep Forum
Originally posted by jeepsr4everSend me more pics of this [email protected]Originally posted by HankrodRistows right.................again,
Originally posted by Fasts79Chief... like the little 'you know what's' that you are.
Originally posted by Fasts79ChiefI LOVE how Ristow has stolen my comment about him ... "Quoted" it ... and made himself famous for being an ***hole to people. Hahahahahahahahahha!
jeepsr4ever, if you make cover plates for all the sealing surfaces, you can hav it powdercoated. Oh wait Summit and sears sell home powder coating rigs, and a t/c is small enough to fit in an oven.Last edited by [email protected]; 06-24-2007, 11:24 PM.65 Kaiser wagoneer 2door Panel AMC Vigilante 327, T-98, D-20, closed knuckle, D-44, on BFG M/T 35s MY DD
79 Cherokee S Desert Camo, project waiting for trans from green
78 Cherokee S Green, salvage heap, w/ blown 360, stuffd full of lots of extra FSJ parts.
Nickle is used as an anti-corrosive coating and is tough stuff. It should be just fine. That sure is pretty. I picked up one of their nickle-coated thermostat housings and it looks pretty good, too.89 Grand Wagoneer, 360, 727, 229, D44s, 2.5" Rancho lift, 31x10.5 mud tires, Howell TBI on an Edelbrock intake, MSD TFI upgrade, Engle cam, Edelbrock shorty headers, Single 2.5" exhaust with 40-series Flowmaster, Milodon high-flow water pump, BJs Offroad aluminum cross-flow radiator.
Current Jeep Status: She's alive!!
I think the nickle will protect the water pump ports from electrolesis.65 Kaiser wagoneer 2door Panel AMC Vigilante 327, T-98, D-20, closed knuckle, D-44, on BFG M/T 35s MY DD
Sorry Dave. I think you should leave it like it is. However, make up some kind of crate base so it won't tip over and mount on a 2'x4' plexiglass top to the intake and use it as a coffee table or something that can always be seen. Would make for a great conversation piece and no one can argue that it's not art. Way too pretty to hide away under a hood!James
1988 GW stock (work in progress)
2003 GC Laredo (family car)
Thought it would be simple, forgot it was a Jeep.
what the ????????? i wasn't selling anything, just asking if the plating would hold up the way it is. that was all !!!!!!!!!I'll keep my guns, money and freedom, you can have the change !!!!!
baybilly = dave
84 J10, parts
51 Willys
88 XJ, DD
It will hold up great! Ni is known for its abrasion and corrosion resistance. It will help from electrolysis and resist any coolant grooves from cavitation.AMC/Jeep Forum
Originally posted by jeepsr4everIt will hold up great! Ni is known for its abrasion and corrosion resistance. It will help from electrolysis and resist any coolant grooves from cavitation.I'll keep my guns, money and freedom, you can have the change !!!!!
baybilly = dave
84 J10, parts
51 Willys
88 XJ, DD
