View Poll Results: Which Header to you prefer
Headman Header 42 23.46%
Doug Thorley 94 52.51%
Edelbrock 28 15.64%
Another 15 8.38%
Voters: 179. You may not vote on this poll
  #41
Old 08-14-2008, 09:25 PM
JPSwapMohn's Avatar
JPSwapMohn JPSwapMohn is offline
behind the headers..
Originally Posted by Herk
Your MPG and performance gains come from whats behind the header as much as from the headers themselves. If you run a 2.25" dual or 3" single exhaust with GOOD muffler(s) you will see a marked improvement over the OEM setup.
Which is the question I am trying to answer for my 78. It has several holes in the exhaust and a broken manifold bolt, so it all needs to come out. Anyone running single 3"? happy with it? Was thinking it might be a good solution since the fuel tank where it is..
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP242, F150 fuel cell, discs, Aussie rear, LDS front, 4.10s
http://imgbox.com/g/rNuIasKYrS
95YJ, STaK 300, D44's, SOA, ARB's, 4.56s, Bilsteins, 35" KM2's
50 CJ3A
77 J-10, 360/T-18/D20, SOLD
Old 08-14-2008, 09:45 PM
Herk's Avatar
Herk Herk is offline
A 3" single flows the same as 2 1/4" duals, or a tad more. Easier to fit.
My comment about the Headmans refers to all of the common headaches with headers. Simply put, many cheaper headers are not quite right out of the box. The flanges may not be flat, you may have to file, beat and tweak them a little.
Headers are an area where you get what you pay for.
Also, unless you have a 4 barrel and a bigger cam, you probably won't see much diference.
Old 08-14-2008, 10:15 PM
mjself mjself is offline
I have the hedman elite ceramic coated with ball and socket collector flanges in my '84. I like them. I normally like the super comps and sandersons. No leaks and I am running duals to a single magnaflow (dual in dual out (serves as my crossover) not a noticable loss in torque at all plus I increased MPG a bit on the freeway.
Old 08-14-2008, 10:45 PM
TPICherokee's Avatar
Much easier to fit.
I have always been told by a lot of muffler places that for the most torque, you want to run one large pipe (3") into a muffler of your choice. If you want dual exhaust, use a muffler that is single in and dual out. It would be just for the look at that point but that is supposedly how you make the most power.
Let's say theoretically, a company, we'll call them AJ's Off-Road, were looking into doing a cat back system for the FSJ's, should they go with:
1. Single mandrel bent 3" pipe exiting in the stock location
2. Doing like above with the single in, dual out having the driver side exit in a factory fashion
3. Both
or
4. Just bagging the idea, it will never work....
Old 08-14-2008, 10:54 PM
coiler coiler is offline
I have thorley headers and flomaster 40 and man it is deep and loud, wife wears ear plugs when we go out for a cruise.
1980 Chief, MPFI 401 thorley headers, 35" cooper stt 4" superlift 3" exhaust.
Old 08-16-2008, 01:28 AM
snoopy snoopy is offline
Clifford and it leaks big time, and it is still a good alternative to the stock manifold. Does anyone make a decent header for a 258?
www.patriotguard.org/ because it does matter.
Old 10-24-2008, 08:03 AM
A lot of people had fixed their leaky 6-cylinder header (or exhaust manifold) with this:
http://www.bjsoffroad.com/CartGenie/prod-584.htm
Old 11-10-2008, 11:57 AM
Our new y-pipes are in. These are specially designed for the 80-91 FSJ's and they fit REALLY nice. They don't hang down like the old DT y-pipes. Just thought I would let you know. They are on the website.
Thanks.
Old 11-11-2008, 06:46 PM
orangecherokee's Avatar
I run Hedman Hedders and maybe they're not great but they work for me and I like them. They also light up in the dark
Old 11-26-2008, 08:40 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
I think I see a UFO!
BJ's Off-Road
ryan@bjsoffroad.com
Old 11-26-2008, 06:22 PM
donwag's Avatar
donwag donwag is offline
Thanks.
Are the y-pipes available seperate from the DT kit? In other words can previously purchased DT headers be upgraded to the newly designed y-pipe?
Don
82 Cherokee
89 Grand Wagoneer
84 CJ7
Old 11-30-2008, 10:33 AM
cajunKen's Avatar
cajunKen cajunKen is offline
I've had a set of hedmans (new in the box) that the PO threw in when I bought the GW. I had been toying with the idea of putting them on with a 3" single exhaust after the 360 needs a rebuild and I throw in a new cam.
I thought I heard something a while back about earlier hedmans being better than the later ones.....anyone know if this is true, and if so, how much earlier are we talking?
Only other header experience I've had was with my '86 Dodge W-150, I put headers, duals & a cam into the 318 it had. Woke the motor up really well, but those headers (Blackjacks, IIRC) leaked like a sieve.
Ken
'87 GW-360, 727/229, TFI, Holley Street Dominator manifold & Edelbrock 1406. Stock lift & tires.
Beef-It's what's for dinner....cause there ain't no d@mn shrimp in Colorado!
Old 04-15-2009, 09:28 AM
Yes, they are available. If you are interested, give us a call at 253.265.6678.
Old 04-15-2009, 07:51 PM
bushwood44's Avatar
bushwood44 bushwood44 is offline
Much easier to fit.
3. Both
or
Does AJ's Offroad have a web site?
88 Grand Wagoneer
99 Camaro z28
73 Honda st 90
79 F250
Old 04-18-2009, 04:29 PM
Ive had several hedders (stainless and coated) and they all leak and even when not leaking theyre noisey. Unless you have an old smog dog with really restictive manifolds its not worth it. The OEM for the last 20 years has done a good job with manifolds and unless your really juicing it up you wont need hedders. Lastly, your only likely going to get half of the gain that the manufacture says that their product produces.
Old 04-18-2009, 07:27 PM
billyrb's Avatar
BJ's Off-Road
wow, your post shows that you haven't done your research. There are independent tests on the better brands that show they gain what they claim. As for all leaking, and all being noisy, again the better brands don't have that problem. The leaking headers comes from thin mounting flanges that warp, or using hardware that doesn't lock in place, as well as gaskets that aren't up to the task. For headers being noisy aside from leaks, that is typically due to cheap headers using thin-gauge tubing, which doesn't dampen the sound enough (ie: pacesetter, blackjack, etc.).
BJ's Off-Road
ryan@bjsoffroad.com
Old 04-23-2009, 08:13 PM
I disagree, Ive read numerous hedder install and when dyno'd with no other tuning they dont produce. Plus, when you consider $400 + for 3% (7hp) increase and the drawbacks of the hedders there's better places to spend your money. Often, a catback exhaust is better than hedders and only worth the money when the OEM has worn out. With CAFA standard as tight as they are, the OEM's have minimized restriction at the manifolds. I remember the manifolds of the 60's & 70's, hedders and daul exhaust made a major difference. Today its marginal.
Old 04-28-2009, 06:33 PM
TooRisky's Avatar
TooRisky TooRisky is offline
What ever your choice of headers, before installing them make sure you dont have to paint them first. I dont know when they started this idea of not painting with heat resistant paint, but it burns off fast and looks fuggly real fast.
1977 Jeep Cherokee Wagoneer, 401CID, th400, D44's, 37"MTR, 7"lift, locked F/R, York OBA,12K Warn, Lotta Love
2002 Chrystler Sebring LX DD
Old 04-30-2009, 06:30 AM
87waggie's Avatar
87waggie 87waggie is offline
Noob!
You definately haven't done much research, the manifolds on the AMC V8 are a 30+ year old design. They didn't change much except for the addition of the smog tubes to keep the government happy. So replacing the 1960's designed log-style manifolds on your AMC V8 will be of benefit to both torque and horsepower, but when you bring fuel mileage into the picture the payback may not be worth it.
87 Waggie - The perfect exploring machine, just fixing things every weekend.
Old 05-02-2009, 06:46 PM
maccj5's Avatar
maccj5 maccj5 is offline
around 70---and earlier amc's were square ports
mac
its a jeep thing i dont understand either
69 m715
87 gw
73 cj5
94 yj
69 j 3000-- dennis got it
81 cj7
66 j truck
78 cherokee cheif
