View Poll Results: Which Header to you prefer
Headman Header 42 23.46%
Doug Thorley 94 52.51%
Edelbrock 28 15.64%
Another 15 8.38%
Voters: 179. You may not vote on this poll
Old 01-18-2008, 11:16 AM
badaboom's Avatar
badaboom badaboom is offline
Doug Thorley Tri-Y.
I have a set for the FSJ 360/401 AMC with Smog air holes sitting in the garage. Most will work, its design can help. I also like to have a pretty thick flange on the header to the engine head. I have also run a set of advance adapter headers I was very happy with but that was on a chevy engine.
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 01-18-2008, 04:18 PM
mattmopar440's Avatar
I know there's the good type of manifolds and then there the bad type, where the pipe leaves out the back instead of the middle does anyone notice a idle sound and torque
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 01-18-2008, 06:25 PM
Menace's Avatar
Menace Menace is offline
Originally Posted by 78indian
thorley headers - $550 - $800
headman - $150
thorley headers might be nice but for $600 more, they could be gold plated i wouldn't pay that much more for what maybe 5 extra ponies and 1 mpg if any at all.
i wish i had money like yall(yous guys-for the yanks) i would invest it in somthing that makes a diference.
hmm.... i can get a detroit locker and a set of hedmans for what you pay for crome!
Yeah that is funny, because with Hedmans you get what you pay for, paper thin flanges, mismatched ports, crappy welds, low quality gaskets, Etc. Be sure to order extra port gaskets with those hedmans, you'll need them!
Old 01-18-2008, 07:23 PM
Ronson Ronson is offline
I have a Thorley on my daily driver that I haven't touched in four years. It just recently started to leak, which is decent even with a stock manfold with an aluminum head.
"Technological progress is like an axe in the hands of a pathological criminal"-Albert Einstein
Old 02-18-2008, 10:16 PM
jepj2000's Avatar
jepj2000 jepj2000 is offline
Originally Posted by BRUTUS
headman because it was cheap! No noticable gains in gas mileage, HP or torque.
X2 and also I hate them and they will not seal up no matter what I do. I would never waste the money on them again.
1972 J2000: 304, T18, Dana 20, Dana 44s w/ 4.09s, Rear Detroit, 7.50-16s
1977 J10: 401, TH400, Quadratrac, partime kit, Dana 60's , 4.10s, welded rear, RS44044s SOA, 63" Springs inboarded, 36" Goodyear RT IIs
Old 02-19-2008, 12:09 AM
gwinn's Avatar
gwinn gwinn is offline
360 AMC
I've been running Edelbrock 50-state legal headers for 6 years. I've also had an engine overheating problem for 6 years. I have tried numerous fixes to cool the engine. My next one is to have the headers ceramic coated to keep the heat on the inside until it leaves the tailpipe. $350 at Jet-coat including the y-pipe. The $700 headers are shipped with a quality ceramic coating. If this is the primary problem, a lot of grief could have been spared if I put a few more bucks into them initially.
1983 Cherokee Laredo "Gus"
Old 02-19-2008, 01:15 PM
2003 mcs 2003 mcs is offline
Who the heck voted for Headmen? Mine are coming off and new manifolds going back on. I will never buy Headmen again-junk, what a complete waste of money and they were their top of the line (ceramic coated?) headers.
2013 Mini Paceman
1985 Jeep GW (coolant leak again!)
1979 Ford Fiesta
Old 02-19-2008, 05:25 PM
Heep80's Avatar
Heep80 Heep80 is offline
I have a set of dougs, but haven't gotten around to putting them on yet. prob look at those bolts and copper gaskets.
80 J-10 with 3in RC lift,1 in. shackles, buckshot M/T 33's. dual glasspack exhaust,eldobrock intake/carb/valve covers/aircleaner k&n, autometer tach, spare tire mount w/ fullsize spare,tool box, 40gal spare tank, grant steering wheel, rhino grill,DPA (Not installed Doug T's Headers, Hi lift jack, cobra cb,tie rods, & dual timing chain
Old 02-19-2008, 09:45 PM
gwinn's Avatar
360 AMC
Originally Posted by jeeping1974
...i finally changed over to studs and am hoping that that will help with the problem.
Where'd you get the studs? Is it a universal stud or AMC specific?
Old 02-20-2008, 09:42 AM
TPICherokee's Avatar
For those of you who have headers with the thin flanges or even with thick flanges and have to retorque them or run special bolts, get these:
http://bjsoffroad.com/cartgenie/prod...pid=583&cid=16
These are a not gimmick, they really work well. I have used them for years and once you put them on, you torque them once and never touch them again. They are thick to make up for a little bit of a warped flange and work really, really well.
Old 04-15-2008, 07:03 AM
Ive got a set of headers on my Cherokee, I dont know who makes them but theyre not hedmans, i do know that. They do leak at one spot but I think a new gasket will solve that. The flange looks pretty beefy too. Is there any way to ID certain headers???
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 04-15-2008, 11:25 AM
Charlie_B's Avatar
Charlie_B Charlie_B is offline
TPI,
I see where the Thorleys are listed as a BJs Exclusive on the site. Is there a limited quantity?
'79 Cherokee "Goldie" - under the knife Part I; Part II
Currently: body is on, now finishing undercarriage
'92 Cherokee "Rusty" - 3" lift, 31s
'05 Evo MR "Eve"
Old 04-15-2008, 12:12 PM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
66-70 have square exhaust ports on the 290,343,390 The hookers are junk for this reason they cut the rectangle in the laser then let some little otherworldly hack go at them with a die grinder I had a fight with them (holley owns hooker) for 6 months regarding the flanges on their header and I know lots of other amcers had issues as well. If you want a good set of headers try to find a set of Kaslers. they are about the best but have been out of production for a number of years, hooker bought them and discontinued the design.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 04-15-2008, 12:37 PM
JeepNOFEAR's Avatar
JeepNOFEAR JeepNOFEAR is offline
I've only had to replace one gasket on my Jeep with my hedmans. Before I started repairing the body it was my DD for 3 years.
76 Cherokee Camo(Parts)
76 Cherokee Camo 401/TH400/Dana300/HD44/14bolt/36s
77 Cherokee blue 360/T18/D20/33s
1969 AMC Javelin SST 390
1968 AMC Javelin SST 290 (Parts)
Old 04-15-2008, 03:13 PM
Menace's Avatar
HMT
Most header Mfg's stamp a number into the port flange. Sometimes that number can be hard to see unless the headers are off though. If you can find that number I might be able to tell you who made them.
Old 04-15-2008, 11:28 PM
Originally Posted by Charlie_B
TPI,
Not limited, when we sell out, we'll buy more....
Old 04-16-2008, 03:35 PM
AlsChopShop's Avatar
headman's are JUNK!
thin flanges that are not flat from the factory, bird-poop welds, and over all crappy fit. of course, the ones i got were for an SBC, but quality won't be any different from the AMC stuff. i went with Flowtech's instead and the build quality is a thousand times better then the headmans.
Al
Old 04-16-2008, 03:38 PM
Charlie_B's Avatar
^^I think Ive already said it...but X2..big time
I cant wait until i have the money for a set of thorleys
'05 Evo MR "Eve"
Old 08-09-2008, 09:28 AM
Millerluck's Avatar
I've been happy for the most part with my Thorley headers. After having no trouble for years. The gaskets started to leak. I had to add some weld in some corners to get them to seal with MrGasket Ultra Seal Gaskets. At the time I was in a pinch. And needed to get it sealed to go to the dunes. I didn't have time to order Thorley gaskets.
Also I had to do some major grinding to make them clear the sparkplugs with Edelbrock heads.
Larry
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
Old 08-09-2008, 10:45 AM
Herk's Avatar
Herk Herk is offline
I had the Hedmans on my 83. All the "joy" of headers without spending big $$$. I re-flattened the flanges and safety wired ALL the bolts and they settled down and stayed leak free for reasonable periods of time.
Your MPG and performance gains come from whats behind the header as much as from the headers themselves. If you run a 2.25" dual or 3" single exhaust with GOOD muffler(s) you will see a marked improvement over the OEM setup.
