Old 04-03-2007, 09:24 AM
tndonor tndonor is offline
aftercooler
The aftercooler is from a Chevy P30 van. It required trimming about 3/4" of the header panel and dropped in like it was made for it.
Ill probably leave the fuel plate as is......trying to keep fuel milage somewhat respectable. I do have a friend that grinds 4B fuel plates if the bug hits me.
Old 04-03-2007, 09:25 AM
crazydog's Avatar
crazydog crazydog is offline
Originally Posted by tndonor
Also bought new NV4500 (chevy with dodge input to avoid 5th gear nut prob) and dana 300.
Are you saying you bought a new NV4500 that has been fixed? Because originally, both the GM and Dodge NV4500 had fifth gear problems.
For more info, see Dan the Gear Man's articles.
http://quad4x4.com/NV4500%205th%20Gear%20Failures%20and%20Solutions.h tm
1967 J3500 - Making plans
Old 04-03-2007, 09:36 AM
Correct, bought a new case......no 5th gear nut problem. Chevy also put the shifter up a little closer to the firewall so this gave some extra floor room which I need for two more shifters
Old 04-03-2007, 09:44 AM
Mikel's Avatar
Mikel Mikel is offline
Nice to see you here... Welcome
1969 M715 6x6
1963 J300 Swivel frame
Old 04-03-2007, 09:53 AM
jeepmj_tj's Avatar
jeepmj_tj jeepmj_tj is offline
I bought a set of gm manual -pedals from a hydroboost truck. Ill get some pics up, may take a few days between work and me driving to where the truck is.
All that is left to do is get the pedals adjusted and lines bled. Run battery/alt cables. Put hose clamps on the fuel lines and start cranking. Im hesitant about putting the interior together until the bugs are gone.
Jeepmj tj......my buddys family has a place on Keowee.....When we head down for trips this summer Ill let ya know in case we want to drool over our trucks
Just look me up.
Oh, This issue of JP mag. there is a feature of J20 with a 4BT in it.
01 TJ-Trail rig
91 MJ-Play toy and work horse
79 J20 Tow Rig- Cummins 6 cyl, DD since 07
Old 04-03-2007, 03:02 PM
Carl Rasmussen's Avatar
Carl Rasmussen Carl Rasmussen is offline
Looks great
I will be doing a 6BT in my GW starting this year some time
Carl Rasmussen
No more cable bills
Android TV box Full setup and configured $150 https://youtu.be/7bAm9RzIgms
Old 04-03-2007, 09:11 PM
jlchilcot's Avatar
jlchilcot jlchilcot is offline
hey tndonor, thats a really nice truck. What color is the paint? Is that the gunmetal pearl used on the TJ's and Xj's? Thats the color I was thinking of using on my J20.
75 J-20 360 T-18
77 Cherokee Chief 401 QT
80 CJ-7
2000 Ford Explorer Eddie Bauer 5.0
2000 Ford F-250 Powerstroke
See my Jeeps here
http://picasaweb.google.com/jchilcot
Old 04-03-2007, 09:35 PM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
I'm an hour away from both! Let me know...I'll bring a B.I.G. drool bucket!
Nice work!
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 04-03-2007, 09:48 PM
Wagabond's Avatar
Wagabond Wagabond is offline
Hows the vibration? I'm pondering doing either a 4bt swap or a supercharged 231 Buick swap.
Americans: We're fat because we have food.
Old 04-04-2007, 11:36 AM
Yes the paint in gunmetal....code pq7. I saw a sample at the paint store and my decisions were over.
Ill be happy to let anywone know in the SC area know of my visits down there. Id love to see what everyone else has.
Vibration...... Im not roadworthy yet. HOWEVER....there is some vibes on startup and shutdown. I rode in an early bronco and it was not noticable compared to a healthy V8. There are many fctors there....isolation mounts....weight of the vehicle. I am heavy enough, it is a not an issue. I am also using a 4B that is internally balanced, with fluid isolation mounts, with a hefty weight.
Old 04-14-2007, 06:12 PM
83 chif's Avatar
83 chif 83 chif is offline
shiny stuff
where do you get that shiny insulation that you have on the floor and firewall? does it have a name besides "shiny installation"? good luck with the build, the truck looks great and its my dream set up.
- Doug
MY HEEP:
daily driver 83' Chero Cheif WT, 3" lift, 6.2L diesel, Getrag 5-speed, NP241, 33" TSLs (scratch that, i sold them to get money to finish the diesel swap), a Superwinch 9K
Old 04-14-2007, 08:51 PM
shiny insulation
The insulation is for air conditioning ducts. You can even get some that has adhesive backing and just cut, peel, and apply. 10-15 dollars per roll is better than dynomat prices!!!
Old 04-14-2007, 10:17 PM
wow,impressive.
you'll have pretty decent torque at highway cruise speed.
Old 04-15-2007, 06:14 AM
janie's Avatar
janie janie is offline
Dexron Impaired
That is one of the most beautiful, drop dead gorgeous trucks I've seen. Thanks for letting me drool and keep the pic's and updates coming.
Old 04-15-2007, 07:19 AM
Mikel's Avatar
Are you saying his truck is better looking than mine????
1969 M715 6x6
Old 04-15-2007, 07:31 AM
Very LOUDLY.......
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 04-15-2007, 07:39 AM
In all fairness.....my truck looked rougher than Mikels when I got it. 3 gallons of bondo, who knows how much fiberglass, 2 gallons of primer, 3 coats of paint, 3 coats of clear, and 4 months later I had a good platform to start with.
I polished a turd of a body the best I could. There were rust gaps in the bedsides I could put my whole hand in. Believe it or not I am jealous of most everyone elses truck because they are a better platform. Underneath all the makeup mine is ugly.
Thats why we do this. Its fun and rewarding when its done!
Old 04-15-2007, 07:48 AM
Mikel's Avatar
You have a beautiful and very well thought out truck, VERY similar to what I'm doing (less lift, VE pump and D70 for mine). I can't wait to see your truck running.
1969 M715 6x6
Old 04-24-2007, 01:01 AM
update
Well here is an udate for those following. I got a stub shaft made to go between the D300 and NP205. Also is the bling for the truck. I found a way to have braided stainless hydraulic clutch lines made. I think it looks infinately better than the plastic line I was going to use.
[IMG]
http://i87.photobucket.com/albums/k146/tndonor/Custom_hyd_clutch_line_001.jpg[/IMG]
Old 04-24-2007, 01:03 AM
J10 6bt 5.9 cummins conversion Phillips889 Diesel Swaps 180 10-08-2013 09:13 AM
cummins turbo diesel j10? 84j10 Diesel Swaps 12 02-08-2011 08:25 PM
