Old 02-13-2019, 09:25 AM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Lokar stuff
Who has hooked up a lokar gas pedal cable, and how..
TIA
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 02-13-2019, 11:59 AM
Lokar stuff is pretty good stuff. Only Lokar cables I've used was a floor shifter set up for a TH400 in a 50 Chev PU. Easy install. I suspect a Lokar throttle cable would be like any throttle cable as in pretty easy but requires the cable sheath to be anchored against movement. So buy or make any brackets needed.
Old 02-13-2019, 08:38 PM
jeepman1's Avatar
not quite
The lokar cable has a slot with a pin through it.. our jeeps have a cable that goes right through the pedal.
: 98 9er
'83 Honcho j10
Old 02-14-2019, 01:32 PM
delta 18's Avatar
delta 18 delta 18 is offline
I have installed the 1000HT along with the 2727HT kick down cable.
From what I remember, you can remove the clevis by removing the pin and pulling the cable all the way out of the cable housing. you can then remove the clevis. The cable does have a little ball end on it and it fit fine on the insert on the pedal.
I'll try and take a picture tonight.
Mike
'87 grandwagoneer,
MSD 6A
229 727 dana 44 axles
Old 10-19-2019, 07:18 PM
KdkGrizz's Avatar
KdkGrizz KdkGrizz is offline
Lokar accelerator cable pics.
Did you ever snap any pics to share?
Kodi
82 WAGONEER It's a project
360ci 727 and NP208
The early bird may get the worm, but the second mouse always gets the cheese...
KdkGrizz's Avatar
Kodi
360ci 727 and NP208
Lokar Shifter StuS77J20 General FSJ Tech 6 06-11-2016 07:22 AM
amc 360+ eliminating emission stuff tommy123 General FSJ Tech 17 10-11-2010 10:05 AM
First teardown of the new 79 Cherk, fun stuff Gambler68 General FSJ Discussion 13 05-02-2007 08:53 AM
Have you guys heard of this stuff? Blinkinlights General FSJ Discussion 12 05-01-2007 09:56 PM
Picked up a bunch of jeep stuff for $31dollars! Heavyjp General FSJ Tech 1 11-12-2003 02:59 PM
