So I have been restoring a 1978 J-10. On the bright side, im nearly finished. However, I have left this strange problem till last hoping it is something I can fix, but dreading that I will have to replace the entire case.
So, my transfer case has a loud, pulsating gear noise that gets louder the faster you drive. Sounds a lot like mudder tires on pavement and the same gear noise you get from backing up fast in a car. The noise is 100% comming from the transfer case. Also, the speedometer bounces badly from 0 to 40 as you drive. the noise pulsates...waa waa, waa waa, waa waa etc.... ?
I have the 2wd conversion kit w 16% od, and am thinking that the rear output shaft may be bent? amazingly, the guy I bought the truck from said the noise was normal, and he had been driving for 6 months without any changes. He said the noise started when they installed the 2wd conversion kit. Also, there is play in the output shafts, as well as in the whole drive train.
I am very new to this type of rebuild, and would appreciate any advice/ experiences.
thanks!
[ August 26, 2005, 01:37 PM: Message edited by: killer whale ]
thanks!
