Old 03-05-2015, 07:10 PM
firedog firedog is offline
Help! Lost all power while driving -- no 12v keyed power
Ok. So here's what happened and here's what I know. I'm near my wits end, with a compressed timeline before we leave for Moab -- and I'm pulling my hair out. Here's the scenario.
Enjoying a nice sunny day, driving the 1990 GW down the road. BAM! motor dies, all power is out, gauges are out, I THINK I see a small white puff of smoke from the engine compartment. Tow it home. Here are some things I've done or that I know.
1.) I have constant 12v battery power at the fuse panel under the dash. i.e.) lights, hazards, etc.
2.) I have NO 12v keyed ignition power to the fuse panel under the dash, no keyed power to starter relay on the passenger side fender that goes to the starter solenoid.
3.) I "jumped" the starter solenoid, between the two posts, spun the solenoid, but didn't engage the flywheel or turn over the motor.
4.) I've checked every fuse I could find between the battery and the firewall -- didn't find any before the firewall.
5.) I've shaken wires while I had the key turned under the dash to see if a connection was loose, partially faulty, etc. no juice while doing that either.
6.) I've replaced the starter relay on the passenger fender with a brand new one
7.) There is connectivity between the starter relay ground and the neg post of the battery
8.) There isn't enough whiskey in my state to un-frustrate me in figuring this out...
Of course these things happen when I'm already packed up to my ears, leave in a month for our family retreat to Moab...and I'm starting to get a little panicky...
Any, all and mostly useful help greatly appreciated...
Cheers gang and thanks in advance!
Respectfully --
M
Old 03-05-2015, 07:47 PM
rockrollin's Avatar
rockrollin rockrollin is offline
Fusable links connected to starter relay. Check for mushy spots.
OI!IIII!IO "I like fun" Eddie Ott
Clawed 90 GW
Slightly off stock
Old 03-05-2015, 09:15 PM
steveomd's Avatar
steveomd steveomd is offline
Bulkhead connector
If the 1990 model uses a bulkhead connector then unplug it at the firewall
clean it with spray can of electrical parts cleaner and reconnect.
If your model uses bulkhead connector sometimes these loose connection because of dirt and oil buildup.
Old 03-05-2015, 11:57 PM
did a continuity test between the starter relay points and downstream of the fusible links by poking through the insulation...the fusible links seem good...?? grrrr what now?
Old 03-05-2015, 11:58 PM
I can not even freakin move those connectors....is there a trick or secret to getting them off?? they don't even budge for me...
Old 03-06-2015, 01:00 AM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
360 AMC
If the 90 is the same as my 81, the connector has a bolt in the middle you have to remove to separate the bulkhead connector.
I think you could have an ignition switch or switch connector issue. I'd check the connector on the side of the steering column first. The wiring diagram on oljeep should help you. http://oljeep.com/gw/elec/90_numeric...nSchematic.jpg
Your symptoms also sound a lot like what happens when the ignition module goes out. Typically no warning at all.
Old 03-06-2015, 02:57 AM
and by ingnition switch, do you mean the starter switch that is connected to the top/side of my steering column? I bought a new one this evening to install tomorrow...which switch connector are you referring to?
Old 03-06-2015, 04:13 AM
rockrollin's Avatar
The ignition module wouldn't kill the guages. Ignition switch is a possibility, but I still suspect fusable link.
Clawed 90 GW
Slightly off stock
Old 03-06-2015, 06:53 AM
acct21's Avatar
acct21 acct21 is offline
On a 1990, fuse #8 is ignition switched -- that feeds:
4x4 indicator lamp
Rear defogger switch
Overhead compass/temp
Keyless entry
Instrument cluster feed
If you lose keyed ignition power, you lose the instrument panel feed. Like I posted on your other thread, I'd start with the ignition switch -- assuming the fusible link going from the battery terminal on the starter relay to the ignition switch is intact.
Old 03-06-2015, 07:08 AM
Are those fusible links a one time deal? Pop and theyre dead? Never seen such.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 03-06-2015, 08:08 AM
TexasJ10's Avatar
360 AMC
I missed the gauges being out in the original post. Probably not an ignition module in this case if the gauges are out. It sure seems like anything that killed the gauges would have taken out that #8 fuse as well.
I had the fusible link issue one time as well. The link itself was fine, but the crimp connection had become corroded under the tape and provided an intermittent connection. It was hard to find because you had to test it somewhere other than the actual connection. It took out all 12 volts not just the run side circuit when it happened to me.
The connector I am referring to simply the one that plugs into the ignition switch that you are replacing. You can see if you are getting "run" power at the switch and then check that it goes through the harness from that point to the relay.
Old 03-06-2015, 08:24 AM
Thats one reason I was asking about the one time dead thing. Maybe it reads good with a multi meter but any sort of load kills it.
Battery terminals are bad for that also.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
Old 03-06-2015, 12:22 PM
rockrollin's Avatar
Usually when a fusable link goes, it's gone. The only times I've seen them burn out is when a direct ground has been contacted (bare hot wire). It is possible too I guess for one to still have a limited contact, that's why I like the mushy test. Most common one is going to the choke on the carb, it gets a lot of heat and the insulation at the end can shrink exposing the wire.
Clawed 90 GW
Slightly off stock
Old 03-06-2015, 03:23 PM
Tripwire's Avatar
Tripwire Tripwire is offline
fusable link - as said squeeze the cables the entire length while pulling gently on them, the insulation is UBER high temp and when the link pops the insulation remains intact so visual is almost impossible
Abort? Retry? Ignore? >
Old 03-06-2015, 06:13 PM
so not being super familiar with the fusible links...are they just in the oversized black portion of the wire...or are they the entire length of that green wire??
Old 03-06-2015, 06:24 PM
rockrollin's Avatar
Green wire yes fusable link, black thingy is connector
Clawed 90 GW
Slightly off stock
Green wire is fusible link wire, black section is crimp to regular copper wire.
Old 03-06-2015, 06:30 PM
Follow the wires everything on the starter relay terminal main lug/post is hot all time. If they are all hot after the fusible links not the problem.
Test each fusible link@ terminal end on relay and past black union/joint/etc.
I believe the choke/carb solenoid(s) feed is NOT on a fusible link.
*if* one of those wires shorted they can cause considerable damage to the engine harness.
It has happened many times sometimes requiring engine harness replacement if real bad.
If you saw smoke something is in need of fixing/replacement.
Old 03-06-2015, 06:48 PM
hookedup50 hookedup50 is offline
I had that intermittant problem for years with the Fuseable links. I would inavertantly wiggle the link and it would run fine till the next time I touched the links. I ended up replacing them all with proper guage GM fuseable link wire from napa. The oem links looked fine and until I cut the insulation and saw the broken brittle wires. Pretty much what has been stated from others in this thread.
Jennifer: 89 GW 360/727/D44 2"lift 31" BF KM2
Harriett: 97 chevy 2500 ext cab P/U 6.5 TD
Lorraine: 73 Datsun 240z
07 Colorado
http://s1196.photobucket.com/albums/aa416/hookedup50/
Old 03-06-2015, 07:09 PM
rockrollin's Avatar
Babywag is correct on the choke feed, I think I'm confusing it with the anti diesel solenoid. Both of which are a distant memory on my rig.
Clawed 90 GW
Slightly off stock
Loss of power while driving!!! Hollywood Dave General FSJ Tech 7 11-24-2005 04:57 AM
hooked up battery terminals wrong-now just clicking... ctjeepman General FSJ Tech 10 09-18-2004 10:23 PM
Driving, W/O Brake Power Booster? jackz4000 General FSJ Tech 7 08-04-2003 12:48 AM
lost some power with carb swap kreb General FSJ Tech 2 09-07-2002 10:57 AM
My J10 has lost power, gas mileage and shakes while running!!! Humpty7 General FSJ Tech 9 02-06-2001 12:44 PM
