Old 11-09-2019, 06:48 PM
itselliot's Avatar
Courtesy light switch
I need info on the door switch to activate the courtesy lights. Could someone please post a foto???? Or a part #...???
( 1978 J20)
the factory holes in the panel are .450" I would buy used ones if someone has 1 or 2....even if they are not working....at least I'll know what to look for in the Dorman catalog or LMC truck.
I do know that the switch will provide a ground when the door is open.
My wiring harness is a Painless one that provides constant power to the lights and the switch provides a ground to complete the circuit when the door is open.
The .450" dimension of the existing holes is the reason I am asking for info/help/
Thanks
hpschrot@hotmail.com
616 four 03 44 0 five
Old 11-10-2019, 09:13 PM
jeepman42 jeepman42 is offline
Exclamation re:courtesy light switch
Try looking up Team Grand Wagoneer. select grand wagoneer- lighting. Page one has a "door ajar switch " listed with a picture & description. Hope this helps
Old 11-10-2019, 09:17 PM
I'd be brilliant if I could remember tomorrow what I learned today!
Old 11-11-2019, 02:57 PM
itselliot's Avatar
Thanks for the response,....that switch is a 2 connector which had me wondering....
I am thinking it's a single connector that uses a body ground.
I found one on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
But I'm wondering if it will fit and adjust properly......
Finally serehill Homegrown Vendors: (Members who produce FSJ related items) 67 09-06-2017 01:24 PM
Brake Light switch thru headlight switch?? gotdirt General FSJ Tech 5 08-09-2017 07:09 PM
Rear Window Switch Thread?? CJ5 General FSJ Tech 21 02-20-2013 08:08 PM
88 gw interior light dimmer switch? Blazin93 General FSJ Tech 6 01-07-2011 11:24 AM
Need Light Switch Expert! No dash lights! Bluesky4x4 General FSJ Tech 2 09-15-2003 04:09 PM
