Pros and Cons of both? The EFI kit from Edelbrock tops $3,000 versus Howell's $1,300 TBI kit. My J20 has the Howell kit already installed, but I wonder what might make an EFI better then a TBI. Is it just the difference of the EFI being electronic?
MPFI vs. TBI
Tags: None
Originally posted by brubakesPros and Cons of both? The EFI kit from Edelbrock tops $3,000 versus Howell's $1,300 TBI kit. My J20 has the Howell kit already installed, but I wonder what might make an EFI better then a TBI. Is it just the difference of the EFI being electronic?
My understanding is that much of the motivation to go to MPI from TBI was emissions related. You might also get a noticeable improvement in performance and mileage. Very unlikely $3000 worth IMO.
The Howell system is basically an electronic carburetor: no spark control, no knock sensor. If you are handy with electronics stuff, you could add spark control (advance under the control of the ECU) to the Howell system. They use the GM ECU, and it's there but not being used.Tim Reese
Originally posted by Billygoatand if you work with Howell they will mod your system for ignition contorol if you don't think you can tackle it yourselfFSJless.... for now....
Originally posted by brubakesI don't think I totally understand the meaning of "ignition control" and its benefit.Tim Reese
tgreese was faster on the draw
It took me a bit working with Howell to get then to mod my kit, but I think they were cautious that they wanted to make sure I knew what I was talking about since it was up to me to mod the dizzy and add the ingnition module, but I had a secret weapon - this forum!
It's EASY to add timing control to a Howell system. At the very least, you need the GM ignition module, a donor ECM plug with some wires still in it (to pilfer from), an ALDL cable and a way to reprogram the chip in your ECM.
http://www.binderplanet.com/forums/f...splay.php?f=75 is a good place to start.
Everything is the same, except that we don't have to modify our distributors as much. All we have to do is lock out the mechanical advance (weld it yourself or have a shop do it. Very easy) and disconnect the vacuum advance.
You could add a knock sensor to the system if you wanted to, as well. Your choice.Ethan Brady
www.bigscaryjeep.com
Originally posted by FSJ GuyIt's EASY to add timing control to a Howell system. At the very least, you need the GM ignition module, a donor ECM plug with some wires still in it (to pilfer from), an ALDL cable and a way to reprogram the chip in your ECM.
Sounds like adding to the Howell kit is beyond my comfort level.FSJless.... for now....
Originally posted by brubakesSounds like adding to the Howell kit is beyond my comfort level.
You sill have to mod your dizzy and add the GM module and coil (they sell the plugs for the coil) i could probably even get you a parts list together.
My dizzy is an MSD so the mechanical and vac advance lock out was supper easy since it is a built in option.
One of these days, I'll put together a write-up. It's not terribly complicated. My conversion took 6 months and that was because I was doing it PT (SlushPuppy is not my daily driver) and I had an issue with the ZIF socket I got from Moates.
If you installed the Howell system yourself, it's not a big step up from that. The only "scary" parts are welding your distributor and you can have someone else do that for you.Ethan Brady
Part of this is to get the most efficient 360 I can. The past owner has already done many things to the 360 to up its reliability and power. If mod increase MPG great! My J20 serves daily driving duties.
NOTE: I know we drive generally fuel inefficient FSJs, but in the end any MPG is worth it for a FSJ. I know they are bricks on wheels and I am NOT complaining.FSJless.... for now....
I think the multi-port is probablly a little better, but not $3000 worth.
I am going to try do a MPI on my new 401 (if the 401 pans out) but working with another member on a DYI system.
Since you already have the Howell kit I would mod it for spark control (either them or you) you should see a little gain in MPG, at least drivablity.
Unless you have a bunch of extra cash laying around and want to do the Edelbrock kit, then you can post up camparisions for us on the same vehical.
