Old 05-25-2006, 06:36 PM
McRoth's Avatar
McRoth McRoth is offline
Flat Top Knuckle Q
Just noticed that I have flat top knuckles on the D44 on my parts J10! I just want to make sure that I can use them on my HD D44 before I tell a member here who offered me some that I found these & don't need his after all.
Thanks!
Mike
Mike
78 WT Cherokee Chief Levis Edition, Rebuilt 401, DUI, Hickey Winch, Headman Headers, Dual 2 1/2" Exhaust.
88 Grand Wagoneer - SOA, D44HD & D60, 203-205 Doubler, Rear Disk Brakes, 36" H1 Double Beadlocks
02 VW Jetta TDI - DD
82 Mercedes 300TD
1953 Dodge B4-F 1 1/2 ton stake bed - Restoration Project
Old 05-25-2006, 06:55 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
All D44 knuckles interchange
Old 05-25-2006, 06:58 PM
McRoth's Avatar
COOL!! Thanks! I was hoping that was the case.
Mike
82 Mercedes 300TD
Old 05-25-2006, 07:12 PM
82j20's Avatar
82j20 82j20 is offline
what years did fsj's have flat tops?? im looking for some for my high steer
burnin the bbq juice
Old 05-25-2006, 07:18 PM
Sloppy Shifter
75 hit and miss I think all 76 I have seen and 77 hit and miss, all that I know of
Old 05-25-2006, 09:50 PM
Firegoose's Avatar
Firegoose Firegoose is offline
My 74 J20 came with flatties
Jason
74 J-20
under construction
360
400TH
dana 20
dana 44hd/60
35x12.5x17 MTRadialClaws 17x10
TFI Upgrade
Old 05-26-2006, 06:29 AM
scotty's Avatar
scotty scotty is offline
also depends largely on the involvement of the various POs in repair procedures. its not uncommon for some people to swap a whole axle cause they have a bad bearing or u joint so you can find flat tops sometimes on earlier or later trucks
also sometimes people swap knuckles around for whatever reason. i got a set of flat tops on one of my 10 bolts,and they definately didnt come that way
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
