This is my 77 Cherokee 4 door. I saw it parked on the road to work one morning and have had FSJ fever ever since. I bought it for $1,200 with 144K on the clock, running strong, but needing a transmission rebuild. The body is straight except for one hole starting in the drivers floor and a little PO bondo work on the right rear quarter panel. It must have been garaged because there is very little rust on it. The paint has seen better days and will likely get another coat in the near future.
Specs & Projects completed:
Replaced tired 360 with Aaron's Remanufactured 360
EGR, PCV, CTO's,vacuum hoses, etc.
Rebuilt Motorcraft 4350 with stock intake (factory)
Rebuilt TH400
Rebuilt BW Quadratrac w/ low range & replaced all vacuum lines
Factory Dana 44 3.54 front & rear (open)
Rebuilt front drive shaft (double cardigan)
Rebuilt power steering pump
Changed alternator
Crown's ABS glove box (NICE!)
New Radiator
New heater core
Swapped A/C compressor & recharged A/C
1" add-a-leaf + 1" add-a-main spring to #2 (all four) = 2" (only 1" shown in picture)
BFG AT 31 x 10.5 on factory aluminum mags
Flowmaster dual exhaust (Y pipe to muffler then splits, no cat, great flow!)
Future Projects:
Corbeau Bucket seats
Tuffy 10" console
JC Whitney's Front molded vinyl floor covering ($169)
Heavy duty 1/2 " or better rubber matting for cargo area
Paint/rhino liner wheel wells in cargo area (inside)
Seal the asphyxiating fuel vapors from the left rear quarter (inside)
Convert to manual rear window (parts on hand/ still debating)
Re-seal all windows & doors
Replace rear window tracking & seals
Paint (gunmetal Grey w/ black top & black Cherokee striping)
Lockers (try Detroit Gearless in back or hold out for ARB)
Heavy duty winch capable bumper w/ full brush guard
Heavy duty rear bumper w/ hi-jack mount
Heavy duty carrier cage (mounted on / replacing roof rack)
Aux fuel tank in spare tire area
Enough lift to articulate with 33s
Do Some Trail Riding!!!!
