I just removed a dash pad from a 1981 Cherokee for use in a 1981 J10.
For anyone that will do a similar removal, I am going to post a brief description of what is required.
First the windshield has to be removed.
Second, there are 6 bolts thru the front lip of the dash pad to remove with hex wrench.
Third, and this is not easy, there are two nuts on the side wings, on each side, that have to be removed. The instrument cluster has to be out and the glove box removed.
Fourth, there are 6 more nuts along the inside (cab side) of the pad that have to be removed from the underside....these are not easy to get to.
But, once all are removed you can joggle out the pad.
