Man you guys know everything! Your awsome [img]smile.gif[/img]
Now that I've buttered you all up here is my problem:
A/C works great, most of the time. I have not had the 86 GW long so don't have much experience with it yet. Here is what I do know. The A/C works great most of the time. Sometimes however it won't blow cold... the compressor does not turn on. If I play with the control a bit it then will work. I would suspect the control but about 1 1/2 years ago this problem was looked at by a shop and they indicated electrical problem and replaced the in-dash control unit. My aunt, who I bought the car from, said it didn't help the problem at all. She ignored it due to living in colder climat and it would eventually turn on if she needed it. She fixed everything with prompt attention exept for this problem.
Could it be a coinsidence that it turns on after I play with the control? A relay that finally works after repeated attempts? Or maybe a clutch that doesn't always kick in? Once it works, it works great. Once I turn on the air, it will cycle on and off with no problems. It is just that once in a while it won't turn on the compressor.
Where should I look?
Thanks,
Thanks,
