Old 04-02-2021, 03:37 PM
melford1972's Avatar
melford1972 melford1972 is offline
Drive by wire or cable?
I'm having a brand new 5.3 LS built using a fresh block (thanks Summit) to go into my Wagoneer. So now I have my choice of throttle bodies.
I understand the pros and cons of each. (DBW means a cleaner engine bay, but requires more tuning, mounting another go pedal, etc.)
So I'm not looking for a list of pros and cons as much as I'm asking for personal experience. For those that have done an LS swap into an FSJs, do you prefer drive by cable or drive by wire. Why?
Old 04-04-2021, 07:45 AM
JeepsAndGuns's Avatar
Drive by cable, always.
The throttle will react how you want it, when you want it.
Drive by wire, they are programmed to where even if you stab it to the floor, it slowly opens, it is not instantaneous. IIRC, I think there are some mods or reprogramming that can be done to help with it, but I have not looked into any DBW systems very deeply. Aftermarket parts and ecm's may be different, but I have seen youtube videos showing it on stock ecm's. I will always stay away from them myself.
The throttle cable is much simpler and there is less to go wrong. With wire, you have to worry about the gas pedal sensor and the stepper motor going out. With a cable, that is the only failure point.
I have even seen a trail fix of a broken throttle cable using a piece of string tied to the throttle. It was just to get them out/off the trail, but it worked. That wont happen with a drive by wire. You will be dead in the water.
Old 04-06-2021, 11:03 AM
Thanks for the response. Throttle response was a big concern. DBC it is!
Help wire this engine test stand... Elliott General FSJ Tech 52 09-06-2010 01:53 PM
Ammeter Bypass additional information... W O S General FSJ Tech 0 08-27-2007 01:12 PM
Battery/starter cable rigging on 1989 Matthew W. Woodruff General FSJ Tech 2 03-10-2004 10:50 AM
Does anyone have pics of their E Drive manual cable activation set-up? barillms General FSJ Tech 12 06-17-2002 04:24 PM
Distributor upgrade for 87 Grand Wag rattletrap General FSJ Tech 35 12-23-2000 12:42 AM
