Old 09-10-2018, 09:36 AM
KdkGrizz's Avatar
KdkGrizz KdkGrizz is offline
TFI Coil Mounting locations - What are other doing?
Hey everyone. So a few ears ago I swapped over to the complete MSD ignition on my 82 Waggy. Previously I was able to fabricate a bracket that I attached to the top of the A/C compressor. Pretty solid location and close to the distributor. Well I just recently updated the HVAC to the Classic Auto Air system which comes with a new compressor, etc. I was never totally comfortable with coil on the compressor to being with.
So I was wondering what are other people are there doing?
Grizz...
Kodi
82 WAGONEER It's a project
360ci 727 and NP208
The early bird may get the worm, but the second mouse always gets the cheese...
Old 09-10-2018, 10:36 AM
kansasboy001's Avatar
kansasboy001 kansasboy001 is offline
I juat got 2 pieces of flat steel stock and mounted the tfi coil vertically on the stock bracket.
1983 Cherokee Laredo. 360/ 727/ np228/ Junkyard 7427 TBI/ Msd ignition
Old 09-11-2018, 09:24 AM
Mr Carts Mr Carts is offline
I mounted the Coil on fender by the cruise control.
1980 Cherokee WT 360 TFI Contour Fan 727 208
3.31 285/75X16 Duratrac's E rated
Old 09-11-2018, 09:39 AM
I cut up the stock mount and mounted it to the drivers side fender. It seemed to work great.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 09-11-2018, 09:10 PM
acct21's Avatar
acct21 acct21 is offline
Got a great OEM mount off a Fox body Mustang. Sits up on the fender well next to the cruise servo.
Old 09-17-2018, 08:17 AM
Found an old pic
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
Old 09-26-2018, 04:35 AM
Brynjminjones's Avatar
I'll see if I can find a picture as I've since removed it, but I used the bracket linked below and got it to fit perfectly in the stock location by the air cleaner.
https://www.americanmuscle.com/ignit...cket-8693.html
EDIT:
I've found a picture, here it is:
https://photos.app.goo.gl/qA1acDDLGXdei7W78
1991 Grand Wagoneer - Hunter Green
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 09-27-2018, 02:09 PM
KdkGrizz's Avatar
EDIT:
Very cool I like it. What mods did you have to do to the bracket. I actually have a couple of those from the junk yard laying around...
Kodi
360ci 727 and NP208
tfi coil bracket to replace stock bracket baybilly General FSJ Tech 17 04-21-2015 05:53 AM
TFI / Accel Coil Question Mudwolf General FSJ Tech 17 03-05-2010 02:09 PM
TFI Coil caionneach General FSJ Tech 4 10-16-2007 06:04 AM
HELP. TFI COIL hook up. RudyC General FSJ Tech 5 12-03-2000 12:37 PM
proper ground on TFI coil Treadted2 General FSJ Tech 3 10-17-2000 05:45 PM
