Advice on redneck engineering
  • mwood65
    • Jul 17, 2017
    • 477
    I want to clean up the top of the intake if possible and remove some things and plug them off with pipe plugs or something.
    Let's just forget that I may be an idiot and lets assume these are good questions!
    I had the picture professionally retouched to help with the questions, please save the ooh's and ah's for later...
    A: Can I remove the EGR and plate it off without any side effects?
    B: Can I remove the whole assembly here and just put in like a 2" nipple for the heater hose to attach to? nothing was attached here I think??
    C: Remove this and plate it off? (I will be using a manual choke)
    D: Remove and put a pipe plug in the whole, Don't think anything was plugged in there before...
    E: Again...don't think anything was there so I want to remove and plu.
    MY MEMORY SUCKS! So if something important should be plugged into something I thought was not plugged into please yell it out.
  • kansasboy001
    • Nov 06, 2016
    • 163
    You can block off egr without any issue if youre not in a emissions state. The CTO closest to the egr controlls the egr so it can go too. The other 2 CTOs control the distributor choosing manifold vac below 155 degrees, ported at operation temp, and manifold again if temp reaches 225 degrees. The idea is to increase advace to keep the engine at proper temperature. Its an emissions thing but also doesn't hurt anything and helps driveability some.
    1983 Cherokee Laredo. 360/ 727/ np228/ Junkyard 7427 TBI/ Msd ignition
    • tarriverarms
      • Apr 21, 2016
      • 45
      Originally posted by kansasboy001
      The CTO
      What does CTO stand for?
      • mwood65
        • Jul 17, 2017
        • 477
        Coolant temperature ??????
        • joe
          • Apr 28, 2000
          • 22392
          override.
          • Heavy_Metal_Thunder_81
            • Jan 10, 2006
            • 7292
            For C, good luck finding the block off plate. I've looked and looked. Going to have one made somewhere.
            -Jonny B.
            AMC 401 - Pro-Flo 4 EFI
            F D44 - 4.10, Eaton E-Locker
            R M23 - 4.10, Detroit Locker
            1979 Cherokee Chief - Parts
            1979 Wagoneer - Sold
            1981 Cherokee Chief - Cubed
            • tarriverarms
              • Apr 21, 2016
              • 45
              Is C a vacuum source? Does it have to be capped? I thought it was a for pulling a vacuum through a heated source for the thermal choke?
              Mine is open, ie the plate has the two holes in it with the tube connecting them.
              • #8
                Aftermarket intake and save the $$ the Chiro would cost?
                • mwood65
                  • Jul 17, 2017
                  • 477
                  I dont think it has to be capped except for looks, I think it is just for heat transfer to the choke....?
                  • mwood65
                    • Jul 17, 2017
                    • 477
                    Would love to if I had the money.......but?
                    What's a Chiro??
                    Is that something like a Churro......or a Burro?
                    • mwood65
                      • Jul 17, 2017
                      • 477
                      I was going to make my own, I have the steel plate
                        • Jan 10, 2006
                        • 7292
                        Those tubes (they coil down into the exhaust crossover in the intake) will eventually crack/rot off from the heating and cooling cycles and you will end up with a nice exhaust leak that you can't figure out. BTDT.
                        -Jonny B.
                        • rang-a-stang
                          • Oct 31, 2016
                          • 5510
                          Yeah, pull the plate out, cut/drill the coils out, thread the holes, and put a bolt in the holes or weld them shut.
                          Chuck McTruck 71 J4000
                          (Chuck McTruck Build Thread)
                          00 Baby Cherokee
                          • #14
                            What's a Chiro??
                            In case you aren?t kidding Chiropractor
                            • andrew williams
                              • Jan 26, 2010
                              • 53
                              as alot of 70s-80s engines were made with all that stuff and it is not needed. the only thing you have to have on it is one vacuum line going to the dist. advance. thats the way they were built for years. but if it's there the automatic choke does need heat to pull off and power brakes need vacuum but that's about it.
