I have found what I am being told is a 1968 Jeep Gladiator j2600. It has a Buick 350 with unknown auto trans? I am assuming TH400, but you all know what assuming does. I am being told that the rear axle is a Dana 55. I can't find any info to support this nor can I find any info on a Dana 55. I am also being told that it has a Dana 44 front axle which is most likely true, but would it have open or closed knuckles? What rear axle and t-case should it have? I have yet to see this truck in person, that is why I am asking these questions. I will post up more info when I see it in person. Thanks in advance for the help.
1968 jeep gladiator j2600?
Tech library: http://www.ifsja.org/tech/figures/db.html#rear
'68 should be an AMC 327.
Maybe a Dana 53? Yes, D44 front.
Closed knuckle. No open knuckles until '72 in CJs and '74 in full-sized models.
Tech library also contains VIN decoding and year-by-year model breakdown.Tim Reese
TH400 and D53 most likely. There is no D55.*** I am collecting pics and info on any factory Jeep Dually trucks from the J-Series at the new Jeep Dually Registry.
it is a 2700 not a 2600
turns out the truck is a 2700 not a 2600. also the fender badges show it to have the 350, as does the vin number decode.
vin is 2406Y19******
The truck is priced at what I think is a good deal, not too much rust and engine runs good, tranny shifts good and t-case works. What are some areas of trouble that I should look for? I have never purchased a jtruck of this vintage(never older than 81). Thanks in advance for the help.Attached FilesLast edited by rustyolred; 07-26-2009, 11:05 AM.joe
A 40 year old truck with no rust is a great score, Congrats to you! First off, replace everything rubber, steering rag joint, fuel tank lines, everything. Start saving for a timing cover. Check out TAPerformance and Postons for 350 parts. Its a good motor. What do you plan on doing with your truck? That will determine how much upgrading you will need to do. The Tech Archive is Your Friend!Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Well besides needing a heck of a cleaning it looks to be in pretty good shape. 3/4 ton 7,000lb GVW trucks are fairly rare to find.Thomas Russell
1971 Gladiator J2000 Platform-Stake Dump 350/T18
1970 Gladiator J3000 3407Z Camper Truck 350/T181968 Wagoneer Custom 327/TH400
