Stock wiring connectors pic/diagram?
  • SkylinePCG
    • Jan 11, 2005
    • 263
    I’m looking for a “road map” of underhood wiring, with visuals of connectors and how the lines were routed from the factory. It may be a pipe dream, but does this exist anywhere?
    1980 Cherokee WT
    360, 727, 219, 35s
    Holley 4bbl, Edelbrock performer intake/cam, TFI, Hedman LT headers, HB brakes, aaaand GW seats!
    Still on the shelf... Hamilton EFI, Transgo TF-2...
  • joe
    • Apr 28, 2000
    • 22392
    The diagrams/schematics are in the factory shop manuals (TSM's) and some years are online at http://oljeep.com/gw/elec/GW_wiring.html
    Don't know of any pictorials of the connectors or specific routing??
    • tgreese
      • May 29, 2003
      • 11682
      I think the only year TSM with a "pictorial" diagram of the wiring was 1972. All the other years have some kind of schematic diagram. The usual approach is to find something you can identify and trace the wires through from there, either electrically or by following them by eye through the loom. Follow along on the schematic. The schematic typically shows conectors and splices, along with wire colors and sizes. "TR" means trace, a stripe on the wire.
      If you have specific things or wires that you can't identify, post up a pcture and ask for help.
      • nograin
        • Dec 19, 2000
        • 2286
        Sounds like you want 'harness routing' as well a wiring diagrams.
        There's far less routing illustrations. I've found some in the Factory Parts Books. Once you have a harness part number, you can sometimes find a better scan from one of the on-line Chrysler-Jeep dealers.
        Best references for original layout is lower milage or unmolested original vehicles. Some sales lit and magazine tests from back in the day have under hood photos.
        In many cases, I've made my own sketches. Just did speedometer cable routing. A couple months ago I did the tailgate - trailer - rearlights.
        I've posted basic main feed diagrams with ignition and headlights on this page.
        I don't think I have posted any routing but do have a pretty fair number of pictures from my '85. What are you looking for?
        '85 Grand Wagoneer
        360 727auto, NP229
        body by beer (PO)
        carries wood inside
        no "wood" outside
        My other car is a fish
        • SkylinePCG
          • Jan 11, 2005
          • 263
          Thank you guys. “Routing” was a better word for what I was thinking.
          And that “oljeep” link was very helpful. Not exactly a photo, but there are visuals of the connectors, and that should be close enough to get started.
          When the snow stops...
          1980 Cherokee WT
          360, 727, 219, 35s
          • SkylinePCG
            • Jan 11, 2005
            • 263
            Ok here’s one that I’m unclear of on the oljeep diagram. This red wire with the white tracer (purple is AC compressor); the unterminated one is the coil +, and will be soldered into the TBI harness. The other one though, if I’m reading the schematic correctly, is either the “capacitor jumper (grid 3A,)” or “anti-diesel and choke feed (grid 3B on the 1979 wire diagram on oljeep,)”
            Either way, I don’t think it’s getting used with EFI. The carbs gone, so no choke, and the EFI Coil has no accommodation for it.
            Am I missing anything, or can I clip remove this wire from the harness?
            1980 Cherokee WT
            360, 727, 219, 35s
            • babywag
              • Jun 08, 2005
              • 10287
              None are "needed" for TBI.
              Take note, the stock coil wire is a poor choice if using it unless you REMOVE the resistance wire. The factory Duraspark module power wire is a better candidate IMHO.
              • SkylinePCG
                • Jan 11, 2005
                • 263
                Can you expand on why that ones a poor choice? I’m just going on Bill Hamilton’s direction on this. Also I don’t have my notes in front of me at the moment, so he may have something in there regarding the resistance wire, but that’s not ringing a bell.
                1980 Cherokee WT
                360, 727, 219, 35s
                • babywag
                  • Jun 08, 2005
                  • 10287
                  The coil wire is a poor choice because the resistance wire reduces voltage in ignition "run" position. So again unless you remove the resistance wire it's a poor choice to use.
                  • SkylinePCG
                    • Jan 11, 2005
                    • 263
                    You beat me back here... I went back through his instructions and he makes it abundantly clear that the resistor is to be removed.
                    What I found though is that one if the starter solenoids small post connections shares the resistor wire, so I had to reconsider my first plan of cutting it out and soldering in a long length of wire to match the rest.
                    I instead will be using that “anti diesel/choke” line to feed the ignition circuit, since it’s the same gauge, ended in the same place by the coil, and shared the same terminal as the resistor wire.
                    1980 Cherokee WT
                    360, 727, 219, 35s
                    • babywag
                      • Jun 08, 2005
                      • 10287
                      Be sure to test for voltage when cranking/key in start position.
                      Whatever wire you utilize must have voltage in both start & run.
                      As mentioned above factory Duraspark wire one of them has both.
                      The other just in run position.
                      It's what I've always used and suggested to others.
                      If you remove the resistance wire from harness you'll have to add a diode to alternator wire or engine will stay running when turn key off.
                      • tgreese
                        • May 29, 2003
                        • 11682
                        You are mixing two different resistance wires. The resistance wire to the coil limits current to the coil when the ignition is in the "run" position. This prevents overheating of the coil and/or module, depending on the application. Tony suggests that you do not use this current-limited circuit as the power feed (not the switched coil feed) for your ignition module, whatever it may be.
                        The wire from the ignition to the exciter terminal of the alternator can backfeed through the ignition switch, preventing a shut down. Jeep also uses a resistance wire here to limit the backfeed current so the engine will shut off. A diode in this position also works.
                        • babywag
                          • Jun 08, 2005
                          • 10287
                          When I initially converted my '90 to TBI it stayed running when the key was turned off. Rather than tearing into the harness, I just added a diode.
                          Same issue as adding an MSD 6 box...
                          His mileage may vary because we don't know what his ignition setup is.
                          • SkylinePCG
                            • Jan 11, 2005
                            • 263
                            My ignition setup?
                            Stock ICM is out.
                            TFI coil is out.
                            Stock wiring to distributor is out.
                            Tiny GM ICM, canister coil, and Distributor all driven by the ECM.
                            1980 Cherokee WT
                            360, 727, 219, 35s
