Old 09-04-2018, 09:09 AM
Probesport's Avatar
Probesport Probesport is offline
Done with distributor, time for coil packs.
My Waggy has been fuel injected (Megasquirt) for some time now and I've been happy with everything save for timing/spark control but I always knew I would go distributorless at some point - and that time has come. I *may* have also needed to do some cleaning/painting while in was in there.
As always a big thanks to my partner in crime Ryan for working through this madness with me
With a DIS setup, we need coil packs, wires, a crank pickup, and some sort of toothed wheel to read crank position. With the AMC engine, we also need a way to drive the oil pump once we pull the distributor.
The starting point
First up, pull and gut the distributor.
Cut down the shaft and housing, inserted a bushing at the new top then welded on a collar to the top of the shaft. The collar allows you to be able to turn the gear by hand for alignment to drop in.
Used 3D Printer and TPU to make a cover for the new distributor stub
We messed with a few options for a trigger wheels, but ultimately decided to make our own via drilling shallow holes in the damper in a 12-1 pattern for the pickup. Back to the 3D printer for a drill template since this has to be precise and maintain balance.
Next up is the crank pickup, used a Ford 2.5l 4cyl crank pickup, mounted to the fuel pump block-off plate.
And a mount for the coils
Wiring harness for the coils
And where it stands this morning.
Next steps are a bunch of wiring, testing, Megasquirt changes, and probably more - probably going Contour fans and using MS to control that as well.
Ken S.
Jeep toy: 1988 Jeep Grand Wagoneer
Megasquirt EFI
: Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
Prior Jeeps: 1997 Jeep Wrangler TJ, 1994 Jeep Grand Cherokee Limited
Other toys: 1930 Model A (Hotrod), 1997 Ford Probe Turbo, 2000 Jaguar XJ8, 2005 VW Touareg
Old 09-04-2018, 04:39 PM
THIS IS AWESOME!!!!
Old 09-05-2018, 09:50 AM
Probesport's Avatar
Thanks!
Installing contour fans tonight and doing a bit more wiring, not much more visual progress as I am pulling out the old disty wiring and re-wrapping everything since we now have a couple more relays for the fans, crank pickup, and coils to blend in.
Ken S.
Megasquirt EFI
Old 09-06-2018, 07:59 AM
Probesport's Avatar
Fan/Radiator side quest completed - http://www.ifsja.org/forums/vb/showthread.php?p=1696090
Will get back on the coils and wiring tonight...
Ken S.
Megasquirt EFI
Old 09-07-2018, 10:30 PM
So, how much for a distributor bushing / cap kit mailed to 95959? With "401" on the top instead of "710" ?
Very slick work.
Genius use of the 3d printer to get a drill template on the balancer, too.
Old 09-11-2018, 08:26 AM
Probesport's Avatar
The bushing is just from the top of the distributor stalk that was cut off. Half went in the new housing and half got welded to the top above a brass washer.
The printed TPU cap is really designed specifically for where the shaft was cut, the 710 lettering is part of the original CAD before it was converted to a printable object. Maybe once I've got some free time I can modify it and print off another.
Wiring and installation is all finalized and we are in the process of tuning now, we ended up drilling the damper out to a 36-1 for more resolution. Pics to come shortly but we did get it started and running last night!
Ken S.
Megasquirt EFI
Old 09-11-2018, 09:20 AM
Probesport's Avatar
Pictures
Adding the ignitor modules for coilpack control to the Megasquirt
New 3D printed drill template to go up to 36-1
and the resulting notches
Ken S.
Megasquirt EFI
Old 09-11-2018, 01:13 PM
Probesport's Avatar
Short video (~7sec) of first fire with the 36-1 and coilpacks.
https://www.youtube.com/watch?v=QnVy3O65OC4
Ken S.
Megasquirt EFI
Old 09-12-2018, 09:11 AM
Probesport's Avatar
Done. Starting and walkaround. Either the injectors are quite loud or my mic is real sensitive.
https://www.youtube.com/watch?v=KyBlOEo7jQ0
Ken S.
Megasquirt EFI
Old 09-13-2018, 09:47 AM
JohnnyJ's Avatar
JohnnyJ JohnnyJ is offline
That's a cool use of the 3D printer. Very interesting work.
Past Project: Stock Class TREC Racer Build Thread
Current project: bringing back my 75 Wagoneer
Old 09-14-2018, 07:28 AM
Probesport's Avatar
Drove it last night and today, it's absolutely never been this smooth on all fronts. Finally feels like a 'regular' car instead of a project vehicle. There is some cold tune work to be done, but other than that this was a fantastic success.
Ken S.
Megasquirt EFI
Old 09-14-2018, 01:00 PM
Are you running a GM TBI unit?
Old 09-14-2018, 01:23 PM
Probesport's Avatar
Yes, it's a GM TBI with reman flowmatched injectors. You can see it more in this pic.
Ken S.
Megasquirt EFI
Old 09-14-2018, 01:38 PM
Probesport's Avatar
If anybody wants them, here are the files to 3D print the items from this project.
Distributor stub cap
https://www.thingiverse.com/thing:3099400/
36-1 Damper trigger template
https://www.thingiverse.com/thing:3099364
The Tinkercad files are available too if you want to modify the design.
Ken S.
Megasquirt EFI
Old 09-15-2018, 02:38 PM
What's the 710 on the dizzy stub represent?
Do you have a build thread on your EFI? I am about to install mine and I am wondering how hard it would be to swap to a Megasquirt computer vice the GM computer I have now... I love what you have done here and am intrigued on how I could copy you.
Old 09-15-2018, 03:10 PM
http://www.ifsja.org/forums/vb/showthread.php?t=180273
Also the sticky of another MS install w/ edis
http://www.ifsja.org/forums/vb/showthread.php?t=136772
Old 09-22-2018, 09:43 PM
Probesport's Avatar
My MS2 install link is in my sig.
The 710 is an old mechanic joke about a customer coming into a store for a replacement 710 cap, which causes confusion until the cap is turned upside down.....
Ken S.
Megasquirt EFI
J20 8,400 GVW Rear Spring Packs SmokinStanley General FSJ Tech 4 01-24-2017 04:03 PM
Hemi Clutch Packs for 727s spyderkeeper General FSJ Tech 1 03-09-2009 03:47 PM
Combining old style main leafs with newer spring packs Gambler68 General FSJ Tech 1 09-24-2007 07:33 AM
spring packs armyfsj General FSJ Tech 1 01-21-2007 12:12 PM
Thoughts on Glass Packs redwings06 General FSJ Tech 34 02-18-2006 02:58 PM
