I'm puttin my new/used steering knuckle back on, I know the outer part is supposed to be filled with some type of lubricant, is it gear oil or bearing grease? For now I used grease and packed it around where the knuckle rotates so as to keep the seal and all lubricated.
closed knuckle 44 question...
According to a post on the m715 zone regarding the same question:
Dana says to use SAE 140 gear oil, the military manuals say to use grease. Personally, I use the gear oil. Some people use a mixture of gear oil and grease, which is probably the best compromise between adequate lubrication and reduced leakage
I personally pack the inside with grease first, and then apply oil.Check out Sore4x4.com for a 4x4 site local to SW Washington/Oregon!
Thanks for the replies, I'm gonna stick with the grease for now ( no pun intended) I figure a little gear oil will work its way in there anyway.73 j-4000 "buttercup"-SOA 36's 4 door cab
78 wagoneer choptop-SOA 36's, 6 point cage, blah blah blah
Yeah you're correct Heep. The earlier Kaiser era D27/44's did call for grease but in the AMC era by 72 at least they changed the lube specs to 140w gear lube in the knuckles.Check out Sore4x4.com for a 4x4 site local to SW Washington/Oregon!
Isn't straight 140 pretty much grease, anyway? Not looking forward to closed knuckles, but am looking at www.sunrayengineering.com at these axles.
Priced out front and rear toghether at a little over $6000, about half of what Dynatrac wants for their Dana 60 axles.Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
?Freedom is never more than one generation away from extinction? by Ronald Reagan.
I use about 2/3 grease (JT-6 red) and 1/3 gear oil. This mixture has been working fine since the mid 60's when I got my first Jeep with closed knuckles.
41 MB<br />46 CJ-2A 307,T90,D18,27,44,4:27\'S<br />64 Traveler, 350,sm465,np205,44\'s w/4:88\'s, spool, 34X9.50 TSL\'s,3\" factory lift, Line-x interior, PS, Dual Optima\'s, custom overhead console,Warn XD900i,custom bumpers<br /><a href=\"http://images.andale.com/f2/116/106/4651773/1009696569938_64trvlrconsolegrp.JPG\" target=\"_blank\">Overhead C
STOLEN! Dana 300 Twin Stick
