Hi, anyone have experience with chinese radiators?
chinese radiator
I have decided to avoid anything Chinese if possible. Sometimes there isn't any other option, but there's no way I would buy a Chinese made radiator. Just like I would never buy Chinese pistons, a Chines quadratrac chain, or Chinese timing gears.
For Christmas I wanted to purchase a nice necklace for my wife. All the jewelry was Chinese made. I was sure to tell the jeweler that I would never ever buy Chinese jewelry. I got the impression that I wasn't the first to tell them.Cliff Danley
1977 Cherokee S
Thank you guys for your input.
I live in Belgium. Only new available radiator that I found in europe is 799 $!
A local company can repair mine, but they can't tell how much it will cost and how long repair will take.
150$ for a new alu radiator delivered at my door suddenly is tempting...1978 Cherokee Chief
360 V8 Automatic
Quadra Trac w/ Mile Marker conversion
4" Skyjacker
mine has worked fine for years and keeps the engine cool at 100 degree temps...Member, FSJ Prissy Restoration Association
1976 Cherokee 401 Quadratrac
4" Rusty's Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
1999 Dakota Seats
2000Tahoe Console
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
I'm with Cliff.
I've been through 3 or 4 radiators. Fit issues, solder seams fail, inlet position angle not the same. The only repop that has been decent is the one I bought from BJ's Off Road. It's actually held up for several years now.
The best will be the original with a new core if the tanks are in OK condition. OK = no pinholes or soft spots. Cores are are expensive. Figure 3 to 400 US dollars. But that is where the cost is.'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
The (Chinese?) aluminum radiator I bought on eBay for my J20 did not fit. It was expensive to send it back (ca $40), but they took it back.
The plastic and aluminum replacement radiator I bought from RockAuto fit perfectly and works great.
Not many places that re-core radiators today. Most "radiator shops" only remove and replace, selling the commodity radiators. Predict replacing the core will be significantly more than a replacement radiator.Tim Reese
I'm running an eBay 3 row aluminum.
Pro's
Direct drop in
Very well made
Works very well
Price!
Con's
Overflow in the wrong spot
Poor threading of the holes
Overflow nipple was damaged (The outlet nipple for the overflow had damaged threads, contacted seller and he sent me 5 new ones.)
I also swapped over to Dexcool at the same time after completely flushing everything. I live in Michigan so I've ran this rad through 100Ken S.
Megasquirt EFI : Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
Originally posted by babywagSome of the brass ones have the overflow nipple on wrong side as well...lol
Aftermarket anything is a roll of the dice these days.Ken S.
