Hi folks -
I had 'Betty's' carb rebuilt this weekend ($170.00 - Ouch!). This is how it looked after I removed the carb. Gasket on top, then spacer, then the thing marked 'this thing' below, then apparently another gasket below that:
The guy gave me two gaskets with the rebuilt carb... Obviously one goes above the spacer, but does the second go under the 'this thing'? Also - 'Betty' has this problem:
I've seen pix of a few other Wag's with 327's and I'm trying to figure out if this happens to most of them, do I have the wrong air cleaner housing or is part of the problem the spacer pictured above...?
Any help is appreciated!
