Old 04-03-2019, 07:48 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
VINTAGE AIR A/C ADVICE
Has anyone put a vintage air into a j-10 ?
some of the units they offer
look just like the factory under dash unit that came on FSJ's.
if someone here has done it,
I would like to know the model you used,
and how you rate installation and performance.
dave in NC
Old 04-03-2019, 10:10 AM
RamJetFSJ RamJetFSJ is offline
Most people use the Magnum IV. Im in the middle of it, so I can't rate performance, but so far, the installation has been fine, it fits well under the dash. I ended up modifying the ABS glove box for more clearance. Brackets that come with it work great on the factory firewall. I modified the front bracket to bolt to the bottom of the front of the dash. I have not done any of the vent tubing plumbing.
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
Old 04-03-2019, 10:55 AM
8man's Avatar
8man 8man is offline
I did the magnum IV with some custom vents in my Cherokee. It cools and heats very well.
Old 04-03-2019, 11:12 AM
asphaltrockdweller's Avatar
I have not yet finished my Waggy, but did buy the Magnum 4 as well.
Over on the FSJNETWORK sonoraed did a really nice install. He is also a dealer for Vintage Air, and does custom lines and control for them.
Check out his J truck build;
http://www.fsjnetwork.com/forum/view...hp?f=12&t=6577
Old 04-03-2019, 01:28 PM
SOLSAKS's Avatar
ramjet, man and rockdweller
thanx for all the advice,...
and I will check that build out.
dave in NC
Old 04-04-2019, 05:15 AM
blazer3664's Avatar
blazer3664 blazer3664 is offline
The Bronco vent plenums that go V/A makes fit well under the dash, almost like they where made for it.
Mine is not done yet, but there are pics on here somewhere.
modified flares, removable top, OBA w/200psi tank,
LQ4, 4L80e,NWF doubler w/upside down 203
SOA w/ D44s F+R for now
H1 wheels+tires (cut), hydroboost brakes
custom shackle flip
W/F150 springs
-----Coming Soon-----
snorkels,
OX'd D60/14B-FF
Old 04-04-2019, 09:48 AM
SOLSAKS's Avatar
thanx for the vent advice blazer.....
dave in nc
Advice and opinions needed please... twmattox General FSJ Tech 8 05-02-2009 05:16 PM
Yet another A/C question Blake General FSJ Tech 4 07-17-2006 12:40 PM
A/C Question - How to purge air from line when topping off refrigerant houstonwag89 General FSJ Tech 6 05-25-2006 09:49 AM
A/C blower is back GED General FSJ Tech 0 07-05-2004 04:16 PM
On board air, and a/c too!! Lindel General FSJ Tech 17 07-21-2001 02:06 AM
