Old 03-03-2019, 02:28 PM
elowsma's Avatar
elowsma elowsma is offline
1978 Wagoneer Hood "Nose Bar" Questions and Repair
First, what do we call the 'nose bar' piece that is attached to older Wagoneer hoods? The part removed in 1979 and later models when the grill took over that real estate?
Second, it is obviously cast, but out of what?
Finally, how are cracks typically repaired on this parts?
Thanks
1978 Wagoneer
401 bored slightly with RV Cam and Howell FI
BDS 4" Lift
Old 03-05-2019, 12:35 AM
letank's Avatar
letank letank is offline
called a hood bar, cracks can be tricky, the hood bar seems to be made of pot metal... depends on how bad the crack is... picts are always helpful
Michel
Old 03-05-2019, 08:16 AM
8man's Avatar
8man 8man is offline
I tried tig, but no go. The pot metal won't take the heat even from tig. JB weld if the cracks aren't too bad will help.
Old 03-05-2019, 10:39 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
plenty of used ones out there, cheap and in good shape
one on eBay now
dave in NC
Old 03-09-2019, 08:09 PM
itselliot's Avatar
Hood Filler bar
I have 2 spares...PM me
hpschrot@hotmail.com
616 four 03 44 0 five
Frame rust repair questions bandit25 General FSJ Discussion 14 04-06-2015 10:23 AM
Heater repair questions alaskakid General FSJ Tech 3 09-19-2011 02:06 AM
A few tailgate repair questions...with pics YoungClayB General FSJ Tech 4 01-14-2008 02:47 AM
Frame Repair questions JeepinAK General FSJ Tech 6 03-20-2006 05:26 AM
