Old 02-21-2013, 03:14 PM
adzam adzam is offline
Trying to salvage my Tailgate trim piece?
I trying to salvage my rear tailgate trim piece. (piece the top of the 88-91 tailgate to protect the rear window when it's down)
It has 7 screw holes in it, and only about 3 of mine are still there as most of the plastic screw "pots" are cracked or long disappeared. The trim pice itself is in pretty good shape so I would like to figure out a way to salvage it.
What I was thinking is since the trim is hollow, is filling it with some sort of epoxy or urethane to give it strength. This would give the working screw "pots" some strength, and also give me the ability to repair the broken holes because I would have new material to drill into for new holes.
Anyone tried any kind of repair on these?
This is the type of material I am thinking of. It's the same stuff you see in bars that is poured and then left to dry:
http://www.homedepot.com/h_d1/N-5yc1...1#.USaMNlqG24c
Old 02-21-2013, 03:49 PM
babywag babywag is online now
I'd stick with a 2 part epoxy, or a plastic repair resin vs what you're looking @.
Usually comes in a syringe.
Home Depot has some, auto parts stores will have some too.
Rough it up a little, tape the holes on the bottom, and partially fill the holes (not to the top).
After it cures peel the tape off, and drill new holes.
I've used bumper repair products on broken plastic pieces with good results.
Old 02-21-2013, 09:02 PM
FSJ Guy FSJ Guy is offline
X2 on the 2 part epoxy instead.
With all the talk of 3D printers, I think the tailgate washer trim piece is a prime candidate. Print it out in 2 or three pieces. Would still be cheaper than paying for tooling and a minimum run of 5,000.
Ethan Brady
www.bigscaryjeep.com
Old 02-21-2013, 10:23 PM
If I do the 2 part epoxy in the syringe, it might cost me a fortune though??? I am planning on filling the entire trim piece with epoxy.
Anyone have a link to a particular brand that I am looking for? Looking for something that doesn't expand too much when drying/setting up. I was going to make a level jig on my workbench, and just fill all the voids and see what happens. Worst case is that I ruin it and I'll hacve to try and find another one.
Old 02-21-2013, 11:01 PM
Tripwire's Avatar
Tripwire Tripwire is offline
how about fiberglass resin? a quart is what 30 bucks or so?
Abort? Retry? Ignore? >
Old 02-22-2013, 01:30 AM
REDONE's Avatar
REDONE REDONE is offline
Where are you? I ain't the only auto-body guy around here, one probably lives near you! Seriously, with all the "issues" surrounding these old things, someone has dealt with it before, some better than others. Puke up some pics or a location and we'll lick this in no time!
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 02-22-2013, 06:10 AM
ProTouring442's Avatar
Use the West Systems Epoxy (You can pick it up at most boating stores). Mix it with chopped fiberglass mat to thicken/strengthen it. You'll also need to sand and degrease the inside of the trim before you pour the epoxy in so it will have a rough surface to grab.
Old 02-22-2013, 10:48 PM
I'm just north of Atlanta. I will take some pics of the piece and see what you guys think. Fiberglass resin might work, I've just never really used the stuff.
I'll try to post some pics this weekend.
How do you properly replace and align the rear tailgate sill Iceman0502 General FSJ Tech 1 01-24-2013 08:37 AM
Looking for this trim piece scram-man General FSJ Discussion 3 12-06-2010 12:35 PM
Tailgate would not latch on right side WWI Flying Ace General FSJ Discussion 1 10-25-2010 08:55 PM
Another trim question -- tailgate Matthew W. Woodruff General FSJ Tech 5 04-08-2003 07:12 AM
clock trim piece ap90c General FSJ Tech 1 11-17-2001 10:34 AM
