  #361
Old 11-08-2019, 02:07 PM
Originally Posted by Full Size Jeeper
Good to hear you figured out the misfire. A lot of parts really suck these days.
Preach it!
Originally Posted by Wagoneer Taylor
Sorry to hear you're sick, but got to work on the Jeep so lose/win haha
Great to hear the smooth idle!!
True! Not as much win as getting to build a house like some folks, but a win none the less.
Last night I removed the rest of the stuff bolted to to the floor so I could clean it all up, install carpet, and install the seats. This is what I have had for flooring for the last 3 years. It is a factory rubbery/vinyl sub-flooring stuff with some matting on the back. I thought maybe the previous owner got it in place of carpet but there was carpet chunks under the seat belt re-tractors (you can see the chunk of factory carpet under my seat in a picture below) which means there was carpet over this flooring and was torn out. I am SURE it was because it was saturated in oil, stunk, was faded, and probably full of rodent poop/pee.
Looking up from under my truck, my floors look solid; No bubbles, no peeling, no dents, notta. I decided to pull up this flooring so I could clean under it. I expected surface rust but it was a bit heavier than I expected with one spot of rust through. If my son's drivers license was not staring me down, I would order a new floor pan from BJs but for now I wire brushed it, coated it in rust nuetrilizer, and am going to put some automotive seam sealer over the rust holes. I am also going to make a metal disc to cover that factory hole to the left of the rust holes. The rust holes are right over the body channel. Yes I know this is not a permanent fix but one of the following will happen:
1) My son will wreck this Jeep sometime in the next 2 years and it will be irrelevant
2) I am going to do a chassis swap/paint job after I move to Idaho (about 2.5 years from now)
So this nuetrilizer should hold me over until then.
OK, Bragging time. I know I have rambled on and on about my seats but am SOOoooo stoked on them! I dropped off my passenger seat bottom parts at a local upholsterer and he redid all the vinyl on the bottom and added new piping ($80). Check out my passenger seat now!
This is the same seat/material as this:
I am SOOOOooooo pumped to get this all back together! Hopefully this weekend I will get the carpet in, Seats in, the steering colum trim back on, the A/C vent in, and generally clean the inside. That will (hopefully) officially make my interior better than a parts rig. Except for the headliner.
Old 11-08-2019, 10:05 PM
Kaiserjeeps's Avatar
Kaiserjeeps Kaiserjeeps is online now
What a transformation! That pattern and the material is really cool. I can't believe the wicking action that took place. Pretty weird looking.
What part of idyho are you aiming for?
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's and a 7
Old 11-08-2019, 11:28 PM
78 WIDETRAC's Avatar
I probably have a factory plug laying around if you'd like it.
Old 11-11-2019, 09:44 AM
Wagoneer Taylor's Avatar
Holy clean seat Batman!!
I still cant believe how good those look!
Some call me Taylor
Soon to be a 401!
Old 11-11-2019, 10:29 AM
seat looks great
good price on the upholstery work too.
I think that neutralizer will hold you for a while.
going to look good with new carpet and refurbished seats.
your son will have one of the coolest vehicles at school.
Old 11-12-2019, 10:06 PM
We bought a house in Boise last summer (summer of 2018). It's about 15 minutes west of downtown, 15 minutes south of Meridian. I want to keep my federal gov pension so I am trying to find federal work up there. There isn't much there for me... If I do not find anything by April of 2020 we will just go after my son graduates high school (summer of 2022).
That's cool. Thanks for the offer, I really appreciate it! I had one. More info below.
Same! So stoked on them. More good news below.
Originally Posted by SOLSAKS
seat looks great
Agreed! Thanks, Dave!
After the nuetrilizer had cured for 24 hours, I used some urethane body sealer to seal up the few rust holes. I also found a body plug in my pile-o-parts so I cleaned up up, stuck it in the hole, and coated the edges with seam sealer and gave it 24 hours to cure. Next, I dug into my stash of spray cans and found the one that had been sitting in there the longest. I didn't really care what color because it was going under carpet. It just happened to be obnoxious yellow. Sprayed that on, gave it 24 hours to cure. I also came across half a can of left over harbor freight undercoating so I sprayed that over the paint. Here is what it looked like before I covered it up:
The passenger side. Previous owner laid some sort of fibrous goop all over the floor. It seems well sealed for now, rock hard, and covered the whole area so I cleaned it and covered it up. Here is what it looked like:
On veterans day, I wrenched for a good 8 hours. Got the $25 Craigslist carpet in! I am absolutely STOKED on it! Fit perfect! I cleaned everything before I put it back in and it came out SOOOoooo nice. Check this out!
If you look under the back seat you can see the color difference between the factory carpet and the Craigslist carpet. I like the darker factory carpet but this will work for now.
I forgot to install the transfer case shift lever and I could not install the trim piece on the passenger side just inside the door because the fiberglass goop covered the holes. If I had another hour to wrench, I would have finished it but it was time to come in. I LOVE MY INTERIOR!!!! Next up, Gotta get that headliner out of there....
Old 11-12-2019, 10:52 PM
Looking great
Rang-
Last night I read your build from page one to the end. You have transformed that jeep. This is a great read. Thanks! Many of the builds are just such a wealth of info on both sites. With the 81 W/T I have yet to pick up I will refer to your build for tips!
What is the upper part of your console out of. It looks way more functional vs the original armrest.
Old 11-13-2019, 08:55 AM
wow,...interior looks great
best thing, it is factory original.
I like the matching door panels too.
great job rang, I know you really like it,...we like it too.
Old 11-13-2019, 10:23 AM
A lot more "How-not-ta's" in here than there are "How-ta's". I really wanted that 81! you got a steal on it! So jealous!!!
Yep! Easy swap from a Buick Roadmaster. Take your time looking for one. Mine is a little hashed internally but "Someday" I will have it recovered in a better matching leather and will fix all the internal cracks. It is MUCH more comfy, brings cup holders, and a storage box.
Here's the thread I copied
Thank's Dave! I can't imagine an automaker making an interior this obnoxious these days. I hope to get the doors rebuilt (including super cleaning and wrapping my door panel vinyls over my men-in-black sourced ABS panels) before Christmas. I also have new scrapers, bushings, fuzzies, gaskets, etc. For the doors. Gonna order some better mirrors, too.
Old 11-13-2019, 06:32 PM
All i can say is Wow!! Looks soo good Rang!!
Some call me Taylor
Soon to be a 401!
Old 11-14-2019, 12:50 PM
rang
it is not obnoxious it is cool, you know that !!!
change sentence to,...they dont do anything that cool these days.
Old 11-14-2019, 07:25 PM
rws31's Avatar
rws31 rws31 is offline
rang
And I agree. Looks great. To much blah nowadays. I love it.
1988 Ramcharger
2003 Durango 4x4
1982 CJ7 4 banger
2008 MB E320 Bluetec
Old 11-14-2019, 08:06 PM
fsj454 fsj454 is offline
Long time member
Talking Perfect
Good things take time .But I woke up one day and my Jeep was done
Old 11-15-2019, 01:44 PM
miracleed's Avatar
miracleed miracleed is offline
looking good man!
'79 Wagoneer Limited
Old 11-16-2019, 12:25 AM
iapexl8r's Avatar
iapexl8r iapexl8r is offline
Nice to see everything is ironed out 😺
1976 Cherokee chief
1970 AMC rebel THE MACHINE
1969 AMX
1965 mustang fastback
1972 international travelette
Yes I have a problem that’s why Iam here
Old 11-17-2019, 10:46 PM
Dang that is as sharp as it gets. I absolutely love those seat patterns. If that were mine I would catch myself going to take another look after dinner and before bed. Just to look...
Am I done yet?
1969 1414X Wag,
1983 FJ60 wagon
CJ-5's and a 7
Old 11-18-2019, 01:01 PM
63J200atLSU's Avatar
63J200atLSU 63J200atLSU is offline
my guy.
That interior looks phenomenal. Great job. Keep it going!
'63 J200 Resto-mod in progress
(http://www.ifsja.org/forums/vb/showthread.php?t=178651)
If all goes well, we can toast to accidental successes.
I'm convinced I'm just too dumb to know that I can't restore this old truck...
Old 12-02-2019, 03:33 PM
Thanks everyone! I really do love the patterns. So in light of that, the doors are next.
I have my doors off to weld these holes shut from my old black elephant ear mirrors.
Step one was remove and dissassemble the doors. Of course once they were off I had to take my truck on a ride with no doors. This is the only Jeep I have ever owned so this was my first experience with driving with no doors. It's kind of cool and I kinda enjoyed it.
While they are sitting and waiting on me to weld them up, I started on the door panels. Here is what I am starting with. Some things to notice:
A) They are pretty darn filthy. Hopefully I can get as dramatic result on these as I did the seats
B) They are super faded but they are as equally faded as the seats so they match and I am OK with it.
C) there are no tears or cracks. I really hope I can keep it that way.
Flip it over and look how awful these are!
Look here and you can see how much they have faded.
I thought this was interesting when I removed the vinyl from the door card; I think AMC pressed the pattern into the vinyl after they assembled the vinyl onto the card because all the areas where a pattern was pressed into the vinyl or the vinyl was bonded to the tweed, it was also bonded to the card.
I ordered a set of ABS door cards from Men-in-black a few months ago (maybe a year ago now?) and have started fitting them. I need to drill the holes for the chrome strips and intentionally did not get the speaker holes cut because I may go slight bigger, or maybe 6x9's here. For now I am going to just get it back together and stereo will come later.
My plan to clean the vinyls is to use the same stuff I used on the seat covers but will only use my pressure washer hooked to my hot water heater. I don't think they will survive a washing machine.
Old 12-02-2019, 10:41 PM
mwood65's Avatar
mwood65 mwood65 is offline
Man I love those seat covers! Would kill for a pair of those....no, seriously I would. You got anyone causing you problems man, we could work out a deal...
Old 12-03-2019, 09:19 AM
I think they will come clean.
I always liked the way the used pattern from seats on door panels.
I would have never thought the emoting came after the panels were assembled.
coming along great rang !
