Cheap chinese poorly manufactured part vs. a nice billet quality made part?
I highly recommend you reconsider that decision.
It running like poo, was likely the cam gear chewed up. The MSD is probably fine.
The gear chewed up is from mismatched gears OR timing chain sprocket oil slot being misaligned.
Could also be a poorly made aftermarket timing cover.
You'll want to try and see if it's an original AMC/Jeep part.
No way to tell now, but if you're going all the way in I'd carefully examine the oil slot.
SC/397 has a very good thread about the timing gear oil slot problem.
A distributor that doesn't even fit properly is a HUGE red flag, get rid of it, or you'll be doing the job all over again.
It is well documented that certain HEI distributors are junk/eat gears.
It will never run right with a chewed gear, most of time not @ all. Trying to get it running with a chewed gear is beyond a waste of time.
Here is one of his threads...
Looks like photosuckit killed a lot of his others about the oiling slot problem.
Originally posted by mommiesmilk
