Old 01-05-2017, 06:23 AM
Greeno Greeno is offline
Noob!
AW4 swap
Hi guys I'm going to do a AW4 swap in my 79 sj does anyone have a wiring setup that works
ive got a compete 97 parts car just can't get my head around the wiring part
Old 01-05-2017, 07:06 AM
SC/397's Avatar
SC/397 SC/397 is offline
I put a AW4 in my Javelin a few years ago. I will dig up my notes and wiring diagrams for you. The main thing I had to do is wire up the nutral saftey switch differently than how the stock Jeep system was. In the Jeep, they broke the ground wire and in the Javelin they broke the hot wire. We used a relay somhow to trick it.
Which enine are you using?
Old 01-05-2017, 11:30 AM
SC/397's Avatar
Kind of a chopped up article but here is how I did it. Mine was from a 1989 Comanche so, your wiring will probably be different.
http://theamcforum.com/forum/aw4-con...opic15549.html
Old 01-05-2017, 12:38 PM
80Limited 80Limited is offline
I'm doing the same swap right now
Old 01-06-2017, 08:42 PM
Did the swap in one of my rigs also.
Upgrades
2. Cs-144 Alt 10/1/11
(Wip)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
Old 01-07-2017, 01:02 PM
TPS question
When wiring your TPS, did you put a step down on it for the 5v input or does it feed the 5v from the TCU? That's all I'm confused on.
Old 01-09-2017, 05:26 AM
Noob!
Thank you big time guys will check out the write up sc/397
Steering colum swap question derf General FSJ Tech 15 02-04-2010 09:01 AM
Muncie SM465, GM 10 bolt 8.5, GM 14 bolt 10.5 and NP 208 swap Chris Barry General FSJ Tech 9 02-26-2007 03:25 PM
my experiences with a 14bolt swap into a cheif malodin Off-Road FSJ Tech 7 01-31-2007 10:54 PM
Turning Radius, Pitman arm? Steering swap. Louiseven General FSJ Tech 5 11-30-2006 12:25 PM
