Old 01-21-2001, 01:07 PM
BIGYELLOW78J10 BIGYELLOW78J10 is offline
Hey
I scored an awesome pushbar off a 70/80's Suburban the other day, and I was wondering what sort of trouble I will get into trying to put it on my 78 J-10. What is the frame width on the Suburban? I doubt the jeep god will smile upon me enough to make it similar to my jeep, which incidently, if anyone knows the outer framerail to outer frame rail width I would appreciate it. My J-10 is currently with my parents, as my mother was driving it last week. Thnaks a lot for any help.
Daniel Toon
78 J-10 Rumblin Wreck
2v 360 V-8
Stock down to the rust
Highway speed in about an Hour
Old 01-21-2001, 01:25 PM
jeepbob jeepbob is offline
Jeep Idiot
according to the FSM 35.38" on the j truck
65 wag. 360/edelbrock rb4/t400/20 t-case/4:10 d27/d44 tracloc/onboard air/onboard 110v power(no inverter)/1999 Lincoln t.c.leather buckets/taurus ctr console/winch/33x12.50/tunes/water proof door pads
soon to have new motor/d44frt/d60r(4:10)welded diff/custom bumpers
see ya in da mud
[This message has been edited by jeepbob (edited January 21, 2001).]
Old 01-22-2001, 12:10 AM
I'll get back to ya.... it was dark outside this morning before I went to work....
Todd
78 Wagoneer, "River Beast"
360/TH400/QT
Dana 44's locked w/ 4.89's
39.50x15x15 Super Swamper TSL's
7" SOA in front-7" Rear Shackle Inversion Mods
4" Skyjacker Softride
3" Trailmaster Bodylift
My FSJ site: http://www.geocities.com/spazz4life
My E-mail: monster_fsj@hotmail.com
"If you can't stop...SMILE as you go under!"
'93 3/4 ton 4x4 Suburban...a.k.a. "FSJ Hauler"
Old 01-23-2001, 05:27 AM
bigjeepguy bigjeepguy is offline
On my 73, it is a little under 35.5 inches.
Old 01-23-2001, 08:29 AM
Gladi8r Gladi8r is offline
Sounds to me like 'BURB' brushguards will fit a FSJ !!
DON
1988 GW mostly stock, <---Wifey's truck (won't let me "fix it up")
1971 J-4000,Rhino Grille(to be installed)
360 CID 8.5/1 ratio 2v, 245 HP, 365 ft/lb
T-18A, Dana 20, PTO, DANA 44 (Front/Rear)
Soon to be torn down for Resto
71 Gladiator Pics
78 GW (parts truck)
360 4v Th400
Dana 44 F/R
http://www.j-trucks.freeservers.com/
78 Wagoneer Pics
Old 01-23-2001, 02:27 PM
Talking
Well, tonight I finally got the chance to check out the Bumper/pushbar/100lb pile o' metal. It measures 28.5" from outer edge of the mounting brackets. So I am headed to the drawing board as to how to mount it up. There is 7" of differece between the overall width outside to outside of the Jeep(thanks guys) and the mounts on the bar. I'm guessing 2" of width for the rail themselves. So that leaves 3". I'd have to grind the mounts off just to move them in 3". what should I do? Should I have some extra steel welded in beside the existing and bolt through it all? Or should I grind the mounts off and go from there. I'd love to keep my 3 piece bumper on the truck, but would that require cuttig through the bumper? Argh! such decisions. Thanks for you help. I'll try to get some pictures up soon! It is awesome.
Daniel Toon
2v 360 V-8
Old 01-23-2001, 04:05 PM
Will it work if you use some steel tubing between them??? Maybe 2" X 3" tubing???
DON
71 Gladiator Pics
78 GW (parts truck)
360 4v Th400
Dana 44 F/R
78 Wagoneer Pics
Old 01-27-2001, 07:01 AM
ibnfe ibnfe is offline
Thumbs up
For those searching for the "brush guard/100# pile of metal". I scored one off of a '91 full size Dodge truck. Fits like a champ on my '85 Grand Wag. I can't use the same mount holes, of course, but being able to use a drill is a prerequisite for an FSJ. Also, Killer 32 Fabrications makes custom bumpers, brush guards for the FSJ. If any of this is already common knowledge, I apologize. Still pretty new.
If my Jeep can't get me where I want to go the way it sits, then I need to modify it some more. After all, Jeeps owners can do anything!
Old 01-28-2001, 11:35 AM
So now I have dilemma. The distance between the mounting plates on the pushbar-28.5. Distance innner rail to inner rail on my rig, 29.5 inches. Maybe I should make spacers out of 1/2" steel plate and run a plate of steel over the top? Or will this compromise strength. I need guidance by some welders. Thanks,
Daniel
2v 360 V-8
Old 01-28-2001, 12:49 PM
Sorry I took soo long... I've been busy with night school and my three boys are in soccer as well....
My frame is 37.5" wide in the back and 34.5" in the front (outside dimensions)
Frank Almaas has a GREAT bumper bracket he fabbed on his site http://www.fullsizejeep.com/
download his drawings... it will give you great insight on new mounting brakcets....I will be using the drawings myself...someday...
Todd
360/TH400/QT (maybe changin' QT soon to a Dana 18/20)
39.50x15x15 Super Swamper TSL's on 15x12 Eagle 589's
