Old 02-15-2013, 07:00 PM
Forrest the FSJ's Avatar
Forrest the FSJ Forrest the FSJ is offline
Another gas tank thread...
Hey guys!
So, I read several threads on gas tank mods/auxiliary tanks and found them all helpful, but still have some questions, as I am going a bit of a different route.
I bought a 1990 Jeep Grand Wagoneer back in September 2012. It has the original soft plastic bladder tank in the coffin-shaped metal "skid plate". The Jeep sat in a field for a long time, but is in pretty good shape - I drove it home
There is a hole in the skid plate where a previous owner put a stump through it (he also crimped the fuel and brake lines in the process). I need to drop the tank to replace the crimped fuel and brake lines. While I'm at it, the plan is to replace the tank and potentially the sending unit while I'm at it. I don't necessarily trust them, and they were sitting in ethanol for <5 years untouched.
Here is what I want to do:
I want to put a +- 20 gallon tank back where the old one was. The only after market tanks I'm finding for 1990 JGWs are 15 gallons, which is pitiful in a vehicle that gets this kind of mileage. Now, since the fuel pump is mechanical and sits on the side of the engine, and the engine is carbureted, not fuel injected, so there are no baffles in the tank, all I need is a 20 gallon container that will fit in the space with a sending unit that will work. I'm currently looking at the plastic 21 gallon coffin shaped gas tanks from MTS that fit in 70s Wagoneers: http://www.mtscompany.com/J-truck.htm
Do you think this would work?
The plan would be to fabricate a skid plate for it.
Also, I want to use this vehicle for overlanding - 4" BJs spring lift with 31"s - so I want good fuel capacity. Here is what I am thinking for that:
Get rid of the under the vehicle spare carrier, and mount an auxiliary tank there. I'm thinking of going this route: http://www.aerotanks.com/inventory/1924.html
What is the easiest way to run an auxiliary tank? What are my options? I can think of several, but am curious what you guys have come up with.
I can't think of any way to do it with just a mechanical fuel pump, which is a bummer, because I really prefer them :/
Old 02-15-2013, 09:16 PM
Mr. Goatman's Avatar
Mr. Goatman Mr. Goatman is offline
http://www.aerotanks.com/vehicles/jeep.html
It looks like there might be one to fit the side where the stock one goes. There are switch valves but I believe they would require electric pumps.
Remember; When it comes to tools and toys forgiveness is ALWAYS easier than permission!
Old 02-16-2013, 01:08 AM
FSJ Guy FSJ Guy is offline
You do know that the OEM tank is not a soft bladder, but it actually a hard plastic tank, yes?
The "bladder" that you might be seeing is a rubber liner that sets inbetween the tank and the skid plate.
Ethan Brady
www.bigscaryjeep.com
Old 02-16-2013, 02:06 PM
On my '83 Cherokee I test fit an XJ fuel tank under where the spare goes.
Old 02-16-2013, 07:25 PM
The "bladder" that you might be seeing is a rubber liner that sets in between the tank and the skid plate.
I actually did not, just made some assumptions based on what I can feel through the hole in the skid plate. It feels pretty floppy, but I'll take your word for it.
Goatman, thanks for the heads up. I really would prefer to keep the mechanical pump, but I'll call Aero for sure and talk with them about it.
Those of you with '70's era Wagoneers, where does the tank go? I'm assuming in the same place as my '90. From what I can see, they look about the same. Anybody ever tried putting a '70s era tank in a '90's era Wagoneer?
Old 02-16-2013, 09:03 PM
The 70s tanks are in the same place and are similar, but different. The skid is also different.
Old 02-16-2013, 09:13 PM
Don't worry. I thought the same thing when I got my first FSJ. Since water also was sloshing around on top of it, when I pushed on it, I heard it slosh around and thought that that flimsy material was all that was holding my gasoline in!
Ethan Brady
Old 02-17-2013, 09:28 AM
On my 1991 I have a aux tank from aerotanks, the previous owner install it. It works pretty good.
Old 02-17-2013, 11:38 AM
Did you see my 72 body swap thread? I put a 40-gal Chevy tank in the back. There's a link in there, I think I paid $92 for a brand-new tank.
Old 02-17-2013, 01:49 PM
newtojeeps's Avatar
The 70's era jeeps were metal pinch seam type. w/ 3/16" thick skid plate. there is a small difference as the transfer case came over to the other side at that time. passenger drop. I read on one of the threads that the older spare placed tanks on the Bronco would fit in the spare tire location. I have never owned one of the Chrysler Wagoneer with the 5.9 mitsubishi starter thing in them.
Old 02-17-2013, 07:37 PM
So, do you think the 70s tanks would fit? I'm assuming the 70s Jeeps use a mechanical fuel pump, too, but the replacement tanks I have seen for 70s era Jeeps (like this one from MTS: http://www.mtscompany.com/images/jeep/0020_v1.jpg) have two large holes in the top in addition to the holes for the fuel lines and filler hose. One of those, I assume, is obviously for the sending unit, but what is the other one for? The only thing I can think of is a fuel pump, and I don't know why anyone would prefer an electric fuel pump to a mechanical one. If that is what it is for, do you think it could be patched effectively if one was going to use an external mechanical pump?
Old 02-17-2013, 08:09 PM
I'm not sure why you would want to swap in an older tank. You would need to obtain or fab a different skid for it and the fuel sender will not work with your gauge. I see the PO put a hole in the skid but I was not sure if that included the tank also. If the tank is good use it. Pull the tank, hammer out the dents, weld patch plates on, and replace. As for a second tank, some have installed one with an electric pump as a transfer pump. Then they use it to fill the stock tank which runs on the manual pump you want to keep. This way there are no extra valves. I'm not sure about safety.. maybe someone else will chime in.
Old 02-18-2013, 02:30 PM
Yeah, not an actual older tank, just an older style tank - the new production Wagoneer tanks that i'm finding for late 80s-early 90s are all 15 gallons or smaller than the original factory tank, whereas it is pretty easy to find new production tanks for the 70s Wagoneers in the 20-21 gallon range.
I think I'm going to go with Aero - it will be a little more expensive, but they come with EVERYTHING I will need, and are good quality. I just got off the phone with them, and for future reference:
Part # 1923A is a 33 Gal front Replacement tank kit for a 1990 Jeep Grand Wagoneer.
Part # 1924 is a 29 Gal Rear mount Auxiliary tank kit.
Old 02-18-2013, 02:34 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
I wouldn't put those in my Jeep. The thin metal is very easy to puncture on a rock / stump, etc. The quality is junk, the mounts are incorrect, and they are flimsy, which is why we don't carry them.
BJ's Off-Road
ryan@bjsoffroad.com
Old 02-18-2013, 02:43 PM
Hmmmm, can you recommend something to use instead? It is by far the most convenient option I have right now...
Also, can I ask how much experience you have had with them? Are there any threads that you have seen on here were members have had issues?
Old 02-18-2013, 02:46 PM
I think he said they are 16 gauge, which is a little on the thin side - I would prefer 12-14, but with a skid plate, it shouldn't be an issue.
Old 02-18-2013, 07:22 PM
Also, two more questions.
My vehicle was severely desmogged by a PO, and I don't really want to put a charcoal canister back on, but I also don't want open fuel lines just hanging, so I want a vented gas cap. Are the stock gas caps vented? If not, where can I get one for a 1990 Wagoneer that is sufficiently vented to avoid issues?
Those of you who have two tanks, how have you routed the lines?
My preference would be one fuel pump (the stock mechanical fuel pump) and one gauge. The single gauge is easy - just run a 3-way switch, like this:
Gauge-----switch-----main sending unit
'-----auxiliary sending unit
Any ideas on how to run just the stock mechanical fuel pump? Is it doable?
Old 02-18-2013, 07:40 PM
billyrb's Avatar
BJ's Off-Road
we make some 27 gallon tanks that are heavy duty, here:
http://www.bjsoffroad.com/prod-1097.htm
They are more expensive, but they are built better, stronger, and fit right the first time.
BJ's Off-Road
ryan@bjsoffroad.com
Old 02-18-2013, 08:31 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
I don't believe the stock gas cap is vented. Just take the cap you've already got into any decent auto part store and they should be able to help. I believe most of the plastic lockable caps that are available for these old Jeeps are vented, atleast the one on mine is.
Many good ways to rig up an auxiliary tank, depends on what you're looking for. Single filler neck or one for each tank? One way to do it without a switcher valve would be to have an electric pump on the #2 tank that pumps the fuel to the #1 tank, IIRC that's how some of the factory setups were done.
Another way would be to use a switcher valve from a Ford or IHC/Land Rover, Ford valve is electric and the IHC/Land Rover would be mechanical. Could also go for an aftermarket electric valve.
The IHC valve is actuated by a choke cable and you can have an A/B switch on the dash for the fuel gauge.
Here's the IH valve:
Only weird thing would be the fuel return line, the IH valve doesn't help out with that but the Ford one does. You can always leave the return line going only to the stock tank.
'65 J2000
Old 02-18-2013, 10:44 PM
Older style tank will hit the rear driveshaft in '80 and newer. (even standing still)
42 Gallon Suburban Fuel Tank Installation (With more Pics!!!) Wagoneerlover General FSJ Tech 42 09-14-2010 08:34 PM
Fuel tank locations and plumbing... Metal Twister General FSJ Tech 3 11-08-2009 05:06 PM
1978 Ford Bronco 25 gallon fuel tank swap in J10! msh227 General FSJ Tech 8 10-16-2009 04:33 AM
Gas Tank and Filter Sock Woes The PIG Smith General FSJ Tech 13 06-16-2008 10:09 AM
Aux tank install Q?s Panther General FSJ Tech 6 08-28-2003 06:52 AM
