Old 02-07-2013, 08:17 PM
Kirk's Avatar
Kirk Kirk is offline
Vinyl Cargo area mat?
Random, I know, but Im looking for a vinyl cargo liner for the rear cargo area. So when throw my muddy boots, something greasy or something small, dead and bleeding into the back I dont stain the carpet (worse than it is) up. I had one in my Xterra, but not sure where to look for one for the GW.
Thanks for leads.
'87 GW
Old 02-07-2013, 08:21 PM
cfg7613's Avatar
cfg7613 cfg7613 is offline
I never could find a molded one with a lip. Ended up buying a generic rubber type of pad from either Pep Boys or Advance Auto - can't remember which.
1988 Grand Wagoneer
360 V8/ 727 Trans
Stock as stock can be !
Old 02-07-2013, 08:27 PM
Kirk's Avatar
Well crap. Good tip tho. Thats what Ill do, even tho a lip would be super great. Any pics?
'87 GW
Old 02-07-2013, 08:30 PM
RWrightPhotog's Avatar
RWrightPhotog RWrightPhotog is offline
Do like I did and rip that carpet out, then use some spray on bed liner!
Rob
1982 Jeep Wagoneer Limited 360
1979 Jeep Cherokee 4-Door 258
1979 Jeep Cherokee Chief 360
Old 02-07-2013, 09:30 PM
CJ5 CJ5 is offline
I looked the other day at Husky Mat and they didn't have anything. I outfitted my Suburban when I bought it years ago. Those things are the ticket.
Chief Laredo Build Album:http://www.fototime.com/inv/BB4AF31A10748CC
'72CJ - Complete Restore
'81SJ - Loredo Resto Project
'91YJ - Rock Crawler
Old 02-07-2013, 09:49 PM
fsj1979's Avatar
fsj1979 fsj1979 is offline
Here's what I just did for mine and I think I like it. It's actually a recycled rubber door mat from Lowe's. They were in the rug and carpet section. I used one for the cargo area and one for the tailgate. They were 3'x5' and are nice and heavy. They also have those deep treads in them, so they can hold some spillage and dirt. The only down side is that I would have really liked to find one that was deeper than the 3'. It doesn't quite make it to the back of the rear seat. You could always buy another though, I suppose. They are like $22.00 a piece. The one on the tailgate, I glued to a piece of 1/8" masonite first and then screwed it to the tailgate, so it's easy to remove when I need to work on the window.(notice I said WHEN I need to work on the window)
1979 Cherokee Chief
2003 GM 5.3 liter Vortec
4L60E/ NP 241c/ Dana 44's/ 33" BFG KM2 muds/ 4" lift
My 5.3 swap: http://www.ifsja.org/forums/vb/showthread.php?t=140105
Makin' her purdy: http://www.ifsja.org/forums/vb/showthread.php?t=140286
Vid: http://www.youtube.com/watch?v=XrqX1ip2KkM
Just keep rubbin' money on it till it shines.
Old 02-08-2013, 08:19 AM
budojeepr budojeepr is offline
Nice!
Don't be yourself. Be someone a little nicer. -Mignon McLaughlin, journalist and author (1913-1983)
Old 02-08-2013, 08:48 AM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
I looked the other day at Husky Mat and they didn't have anything. I outfitted my Suburban when I bought it years ago. Those things are the ticket. Yep, did the same thing with my wife's Tahoe, they are the ticket, too bad they don't make them for the fsj's
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 02-08-2013, 10:18 AM
serehill serehill is offline
Gone,Never Forgotten.
Absolutely
Fantastic solution. bed protectors are good too.
Recut & fit
http://www.amazon.com/Protector-F-15.../dp/B0009XQG56
pep boys has these things too.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 02-08-2013, 10:49 AM
fsj1979's Avatar
Recut & fit
Thanks! I thought about the bed protectors too and that would have covered the whole floor. I just really liked the pattern in these mats as far as trapping dirt and spills. I also liked the price. Under $50.00 for the bed and tailgate. The other thing I like is that these mats don't give off much smell. I did have a stall mat in it before, that I cut to fit and it worked great too. It was 3/4" thick and ridiculously tough, but it just never did stop stinking up the Jeep. If any local guys are interested in that mat, I do still have it, if you like the smell of rubber.
1979 Cherokee Chief
Old 02-08-2013, 11:30 AM
men in black's Avatar
I get that black rubber diamond plate, that would make great flooring.
Old 02-08-2013, 11:40 AM
yeppers
Anything made wiith polycarbons/resons will smell as long as it is heated from the exhaust & sheet metal from the floor board. These are heat manufactured processes & when heated they will smell. The mat was not inteneded to do this. Kind of like when you smoke the tires you smell rubber. It's still a great idea for some. as these polys dry up the smell will go away.
I prefer the insulation from my FATMAT & insulated carpet. heating & air conditioning lose out on this stuff but it depends on what you do with your rig & where you live.
I would think it's a great sound deadener.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 02-08-2013, 01:04 PM
fsj1979's Avatar
Yeah, that stall mat is over a year old and it always smells. More when hot, but it smells cold too. I was told it would get better with some time, but it was still pretty bad. I'm thinking it might just be that it is 3/4" thick. That's a lot of rubber. The mats I have now only have a slight smell and it's a better smell. I actually have 3/8" polyethylene foam padding glued to the floor under the mat too for insulation. I used it to insulate the roof and new side panels too. LOVE it! SO much quieter!
1979 Cherokee Chief
Old 02-08-2013, 01:37 PM
Even more interesting.
The foam should help a lot..
MIB 's solution would also be awesome. that would look great.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 02-08-2013, 02:20 PM
Doesn't BJ's sell the ACC vinyl floor for the cargo area separately?
Dunno if it has the wheel wells molded in. Might not fit well over the carpet.
Tire in cargo area Gurinski General FSJ Discussion 7 09-17-2010 06:41 PM
Cargo area tie down and organization solutions - what are you using? will e General FSJ Discussion 7 05-27-2010 11:41 AM
12V Outlet in Cargo area? JohnG General FSJ Tech 11 09-03-2008 08:23 AM
Cargo Area Liner & Floor Mats cfg7613 General FSJ Discussion 1 03-16-2007 08:33 AM
Water in my cargo area JohnIL General FSJ Tech 7 09-21-2006 10:33 PM
