Old 01-13-2013, 02:48 PM
Austin 4x4's Avatar
Austin 4x4 Austin 4x4 is offline
Novak Gen III motor mounts
ok so i am trying to install these in my '73 j4000. problem is that the bolt holes dont line up with the holes on the frame. there are six holes in each mount, i can only get two per mount to line up. the instructions are not very good when it comes on how to mount these? i am guessing that the longer mount is the driverside, they are marked passenger and driver with marker, but they could be wrong? so how are these supost to mount in this application. should i just use the two bolts and weld the rest, i will weld them no mater how many bolts.
'73 J4000 4 door longbed http://www.ifsja.org/forums/vb/showthread.php?t=120147
'85 Wagoneer
YES i WILL be in ouray in 2013!
Old 01-14-2013, 01:45 AM
Sounds like they may be backwards? Pre '79 are a different kit from post '80
Old 01-14-2013, 08:32 AM
budojeepr budojeepr is offline
A pic would be nice...but when I put Novak mounts on mine I used two bolts, then welded the edges to the frame, then rosette-welded the holes to the frame. They're not coming off easily!
Don't be yourself. Be someone a little nicer. -Mignon McLaughlin, journalist and author (1913-1983)
Old 01-14-2013, 08:29 PM
Austin 4x4's Avatar
On the website it says. They fit all years. The look just like the direction. Just the bolt holes dont line up. I think i will just use the two bolts and weld them.
'85 Wagoneer
Old 01-14-2013, 08:32 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Be we worth the quick call to Novak if you haven't yet. They're really good to work with generally.
aa
novak powertrain swap hjbald General FSJ Discussion 2 10-17-2012 06:10 PM
Novak Powertrain Package? paulie General FSJ Discussion 5 05-16-2012 07:21 PM
Swapping out the TH400 for a GMTH350 with Novak or A.A. wickedwagon767 General FSJ Tech 18 05-31-2008 08:46 PM
Flex plate - TH400 spacers Novak kit Subic Jeep Off-Road FSJ Tech 3 09-30-2007 03:21 PM
Novak says AX15 ok for most V8s Chero77 General FSJ Tech 6 04-29-2002 03:35 AM
