My truck has done this since I got it running. When the motor is warm or hot it labours to turn the motor over, sometimes. It's not consistent.
I have replaced:
The starter
the cable between the starter and the solenoid
the cable between the solenoid and the battery
the battery
the ground cable
I have not replaced the solenoid because the previous owner said he did and it looks new.
My timing is at 10 degrees and I am going BONKERS trying to get this truck to start when it's warm/hot!
When the starter does finally get the motor turning, it fires right up into a low idle. I don't understand what could possibly be doing this, that I haven't already replaced.
Should I make a heat shield for my starter? Does anyone else's do this?! GGGrrrr.....
I have replaced:
The starter
the battery
the ground cable
