Old 11-18-2017, 05:48 AM
Chris R's Avatar
Chris R Chris R is offline
Rear dust shields for early wagoneers
I found a set of these yesterday and need history. I assume these were an aftermarket pieces that were mounted up so the wind would keep the dust from building up on the rear window? Or am I way off base here? Any info would be appreciated. I only found this one photo on the interweb that shows what they look like[IMG]http://[/IMG]
Old 11-18-2017, 12:23 PM
They were either a dealer installed option or owner install. My 63 has them and had them on a later era Blazer. Also seen'm on 60's/70's era station wagons. Yeah, their intent was to help keep the gate window clean from dirt/snow. Though worked better than the goofy later era roof mounted air dams they still didn't do much at all. Only good point is they are kinda period correct cool looking but really more form than function. If you live in the road salt/rust belt I personally wouldn't drill any holes in the body to mount them.
Old 11-28-2017, 02:03 PM
Originally Posted by joe
Only good point is they are kinda period correct cool looking... I personally wouldn't drill any holes in the body to mount them.
I agree. They are OK looking but not worth a hole(s) in the body. they kind of look like horse blinders in my opinion. Though, if you already have some rust or a dent back there, they might be good for hiding that.
now those cool, faded logos on the tailgate and door... THOSE are awesome!
79 Cherokee Chief Wide Track, In pieces
axle isues - D53 and 4.27 front vs 4.09 rear hzl6cm General FSJ Tech 15 08-13-2004 06:29 AM
Rear Disk Brakes (again) - ZJ? Wilsmick Off-Road FSJ Tech 11 08-06-2004 08:49 AM
Dennis? GM rear srings=better rear axle placement? Oracle General FSJ Tech 1 05-27-2002 11:32 AM
rear driveshaft angle - vibration problem miked General FSJ Tech 4 08-30-2001 10:28 AM
Wide trac axles in a Wag(8 posts) Panther Drivetrain 0 08-18-2000 04:33 AM
