Originally posted by babywag
Wires confirmed.
How do I check mechanical advance? When rpms are up I checked the timing and it was a 25 degrees from 10 base. No idea what rpms were.
No way to compression test, I lack the tools. Also the engine really seems to run spot on unless you blip the throttle. It's barely got 67k miles on it so I'd hope it's not a mechanical failure. I know it's possible but I'm the eternal optimist.
While checking the wires I double checked (for the 15th time) my vaccum lines and noticed a drip of fuel from the port for the power valve when I pulled the line off. I'm gonna assume that means it needs replacing. I have a kit sitting right here so it's no biggie but I'm just curious could a bad power valve cause this?
I'm relatively inexperienced with carbs outside the vw world. Most of my builds have either been fuel injected or diesel.
